Please check my line
- Please check my line
22-11-2013 10:56 AM
Can you please take a look at my line for errors. It’s been fine for ages until the last week or so and now it keeps dropping connection.
I’ve done the usual and changed filters, router and in the test socket but it’s not helped.
Its starting to drive me mad..
Thank you
Re: Please check my line
22-11-2013 11:20 AM
I've posted a graph of your connection below:
<img src="http://community.plus.net/visualradius/generated/image13851189505067.png"/>
I've also noticed that your downstream SNR margin is set at 3dB, it might be worth is setting this to 6dB to see if this helps?
22-11-2013 11:26 AM
What do you think could be causing this?
My SNR has always been fixed at 3 and has been fine..
22-11-2013 11:35 AM
Also, have you been turning your router off longer periods of time?
22-11-2013 11:45 AM
It router is never switched off.. I left it off the other night as it wouldnt connect to the internet so I thought instead of it keep connecting and dropping which could end up reducing my speed I turned iit off and tried it again the in the morning.
22-11-2013 12:17 PM
You've lost connection several times for quite a long period which is concerning with the drops you're having.
22-11-2013 12:21 PM
22-11-2013 12:30 PM
22-11-2013 12:38 PM
If I can get one and plug it in do I still use the test socket and when can I expect to hear?
22-11-2013 12:46 PM
22-11-2013 12:47 PM
