Please bump my IP Profile back up (I've been testing a variety of routers)
- Please bump my IP Profile back up (I've been test...
11-12-2012 10:36 AM
I've been testing out various routers and wiring around my home - which means I have been disconnecting from broadband lots.
As a result, I believe you have dropped my IP Profile down to 1.25Mbps which is equating to download speeds of around 1200kbps when I used to easily get 1700+ kbps (even 2000 on a good day :))
Could you bump me back up please as I don't have any stability issues at the higher rate.
Very much appreciated - as family are complaining
Re: Please bump my IP Profile back up (I've been testing a variety of routers)
11-12-2012 10:39 AM
Can you post the stats from your router noise margin, speeds and attenuation
11-12-2012 10:45 AM
Welcome to the community forum
I've placed a SNR reset on your line as your line is capped. This usually takes affect within 4 hours, your line will be in a training period over the next 10 days so please try an refrain from turning your router off.
Let me know how you get on.
11-12-2012 11:12 AM
Hi Oldjim - I think the above should do the trick (as Ive had similar issue before) but here are my stats (which TBH I have never really looked at!). Are they "ok" ?
--- System Information ---jim:green Wireless SSID removed for security mod:end
Vendor: Linksys
ModelName: WAG160Nv2
Firmware Version: A2.00.17 , 2010-02-02T19:47:07
GUI Version: A2.00.17_007
Boot Version: 1.0.37-5.4
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: G.DMT
DSL Channel:
DSL Upstream Rate: 352 Kbps
DSL Downstream Rate: 3168 Kbps
Down up
DSL Noise Margin: 6.3 dB 6.0 dB
DSL Attenuation: 58.0 dB 31.5 dB
DSL Transmit Power: 18.1 dBm 12.5 dBm
--- Wireless Information ---
Wireless Driver Version: 1.3.1.146
Wireless Tools Version: 28
Wireless Status: Enabled
Wireless Wide Channel: 9
Wireless Standard Channel: 11- 2.462GHZ
Wireless SSID: <snip>
11-12-2012 11:27 AM
However you have a problem
Your upstream rate is far too low - I would leave it for the 10 day training period then have a look at the result from the test socket (if you have one)
11-12-2012 11:50 AM
11-12-2012 11:51 AM
Quote from: ericnel ... here are my stats (which TBH I have never really looked at!). Are they "ok" ?
If you are trying to test different routers and wiring configurations then you are very unlikely indeed to get meaningful data about your boroadband connection unless you look carefully at your router stats.
Edited to add specific reference to broadband
11-12-2012 1:37 PM
- give best wifi coverage in the house
- whilst working with all our devices/apps
e.g. one router disliked one online game - documented issue with firmware it turns out.
Hence download speeds wasn't something I was looking at while doing it.
Then when I settled on the cisco I noticed my download speeds had dropped significantly over the week and my IP Profile was now 1.25. Hopefully next few days should see it step up again.
11-12-2012 2:00 PM
11-12-2012 5:49 PM
Just done a Pingtest.net .... OMG... my line has never had a ping of less than 45ms in 4 years. Now getting 25ms each time!!!
Let me at BF3 later this evening! (i'd almost take slower download speed with a sub 30ms ping!)
12-12-2012 3:11 PM
25 to 30ms ping for... 4 hours
Now back at 45ms - but was doing weird stuff all last night, spiking at 500ms, hence 45ms sounds good again
But good news is my broadband download speeds are edging up again since the SNR reset. Now at 1500kpbs (up from 1200kbps).
Just a shame the low pings went away....
Lets see what next few days brings...
12-12-2012 3:42 PM
