Please Could I Have My Activation Date?
- Please Could I Have My Activation Date?
- « Previous
- Next »
Re: Please Could I Have My Activation Date?
30-03-2013 1:31 PM
Hello again,
I am pleased to confirm that the SNRM has stayed at 6dB as promised. The peak-time speed issues seem to have improved too.
I was wondering if the upstream SNRM could be reduced to 6dB as it was before, to allow the line to sync at approximately 1000Kbps upstream as it did before (on my previous ISP). We do quite a bit of uploading and gaming and the extra speed would help somewhat.
Thank you once again.
Message 61 of 68
(581 Views)
02-04-2013 11:50 AM
Message 62 of 68
(581 Views)
05-08-2013 2:47 PM
Hello again,
I have been monitoring my connection recently and I am concerned about the errors. I seem to get thousands per day, with lots of severe error seconds too:
Line state: Connected
Connection time: 5 days, 18:54:11
Downstream: 8,374 Kbps
Upstream: 888 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 4.9 dB / 11.4 dB
Line attenuation (Down/Up): 43.5 dB / 22.2 dB
Output power (Down/Up): 0.0 dBm / 12.8 dBm
FEC Events (Down/Up): 8494038 / 9970
CRC Events (Down/Up): 18654 / 424
Loss of Link (Remote): 0
HEC Errors (Down/Up): 460878 / 1045
Error Seconds (Local/Remote): 0 / 172
Upstream: 888 Kbps
ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Message 63 of 68
(581 Views)
05-08-2013 3:16 PM
Is it affecting your use of the connection? If not I'd recommend leaving things as they are, as any attempt to reduce the number of errors will certainly involve either turning on interleaving or increasing the SNR of the line.
Message 64 of 68
(581 Views)
08-08-2013 11:07 AM
Hi Matt,
It is somewhat affecting my connection. The connection does stop completely at certain times of day and a couple of minutes later, everything starts working again.
Message 65 of 68
(581 Views)
08-08-2013 3:58 PM
Fair enough, sorry to hear that. Would you prefer to have interleaving enabled, or the target SNR increased by 3dB? The latter would probably be better as while it would slow your connection down, it'll reduce the number of errors without increasing the ping times significantly.
Message 66 of 68
(581 Views)
08-08-2013 4:13 PM
Quote from: Matt Fair enough, sorry to hear that. Would you prefer to have interleaving enabled, or the target SNR increased by 3dB? The latter would probably be better as while it would slow your connection down, it'll reduce the number of errors without increasing the ping times significantly.
Let's get interleaving enabled.
Message 67 of 68
(581 Views)
08-08-2013 4:44 PM
Sorry about this, unfortunately didn't check your line before I posted the above. It seems interleaving is already on, so the only recourse we have is to increase the SNR - I can have a word with Chris and see if we can do this such that you're still not affected by DLM, but it will reduce the downstream speed somewhat.
Please let us know if you'd like to go ahead with that?
Message 68 of 68
(581 Views)
- « Previous
- Next »
