Planned Traffic Management Platform Maintenance - Friday 8th June 9am-midday
- Planned Traffic Management Platform Maintenance - ...
08-06-2012 6:51 AM
07/06/2012 @ 11:23
When's this work happening?
Tomorrow, Friday 8th June.
What does it affect?
Our traffic management platform.
How long will it take?
Up to four hours.
What does the work involve?
We're opening up some virtual routes that will see customers connecting to our new E100 traffic management switches. Customers connecting to the following gateways may see their traffic routed through the new platform:
ptw-ag01
ptw-ag02
ptw-ag03
Am I likely to notice the work?
No.
Is there anything else I need to know?
No.
Kind Regards,
Matt Taylor
Customer Support
Has this work started earlier than planned?
Throughput this morning at 06:45 is poor, despite disconnecting/reconnecting the router a couple of times.
The FTTC modem is still in sync at 28.5Mb, but throughput is down to 19.5Mb or less & ping has almost trebled.
Currently:-
You are currently connected to the gateway known as pcl-ag04.
This is located in City Lifeline House.
Re: Planned Traffic Management Platform Maintenance - Friday 8th June 9am-midday
08-06-2012 7:09 AM
Try a different speedtester or choose another server.
08-06-2012 7:31 AM
I was just flagging it as a potential issue (side-effect) to be looked at.
The work isn't supposed to actually start until 9am, so it might well be a different issue, or something at my end.
I have indeed tried a number of speedtest.net servers, different speed testers & different Plusnet gateways.
At this time of a morning, throughput is usually at its max, with a straight line graph.
I do check regularly.
Today the graph looks like saw teeth, regardless of server or gateway.
adie:quote
08-06-2012 8:03 AM
Edit: mind you, could be due to BT maintenance.
Quote Because whenever Plusnet have made "improvements" recently, things that shouldn't be affected do sometimes seem to be affected.
08-06-2012 9:29 AM
The work will see traffic for some customers on the three gateways listed take a different route from the gateway to our core network, using our new E100 traffic management switches.
Other customers will not be affected and trust me when I say, you and pretty much every other customer on the platform would see more then some speed loss if the network decided to route data in a way that did cause problems.
In regards to the graphs, is the the ones on the following page?
http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml
These graphs are due to change, as we have a flaw in the way the data is collected. Right now they do not report correctly. I have attached two 24 hour snapshots of WBC which is based on the data for the graphs we aim to publish in the next 2 weeks on that page.
08-06-2012 10:41 AM
I was "hoping" it might be due to perhaps some behind the scenes preparation work, which would mean I would not even try rebooting my FTTC modem as I am right in the middle of proving my connection's stability following recent engineer repair works.
The saw tooth shaped graphs I mentioned were actually the ones shown in all speedtest.net tests this morning.
I do NOT generally suffer from any contention issues, regardless of time of day/night & at 6:30 or so in the morning, I would expect the speedtest.net graph to flatline at maximum speed.
The attached is a little smoother, but still worse than usual
08-06-2012 11:35 AM
The attached is how a speedtest.net graph should look - anything less regular than that is an indication of contention somewhere.
08-06-2012 11:51 AM
08-06-2012 5:47 PM
Quote from: P
The work you originally listed is not related to the speed issues you are reporting.
So what might the issue be then?
I followed your advice in another thread to reboot the FTTC modem & Netgear WNR 1000 router.
Sync speed is now 29185k against an attainable rate of 34508k.
You are currently connected to the gateway known as ptn-ag04.
08-06-2012 5:54 PM
08-06-2012 5:59 PM
Quote from: Anotherone And guess what, the weekend intervenes
I think I have become very cynical over the last 11 months of "issues", that finally appeared to have been resolved - until today's traffic management "improvements".
Surely, it's too much to be pure coincidence?
08-06-2012 6:51 PM
08-06-2012 7:19 PM
This has been unusually poor all day today.
