Planned Restart
apjashley1
Planned Restart
I need to power down the router to install a new RJ11 cable and new (very expensive!) filter.
How can I do it without triggering DLM - bear in mind I'm still in the training period.
Fixes: 131
Re: Planned Restart
A one-off event shouldn't trouble the DLM.
Customer and Forum Moderator.
Re: Planned Restart
During the day, never at night is my rule of thumb.  After I get up 7ish and no later than 6pm
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: Planned Restart
As mentioned, a one-off drop should not cause you any issues. If you wanted to be even more cautious you can login to your router and manually disconnect your session by clicking disconnect, and to reconnect just login and click connect.
