Planned Restart
- Planned Restart
Planned Restart
19-01-2013 11:27 AM
I need to power down the router to install a new RJ11 cable and new (very expensive!) filter.
How can I do it without triggering DLM - bear in mind I'm still in the training period.
Message 1 of 4
(680 Views)
3 REPLIES 3
Re: Planned Restart
19-01-2013 11:49 AM
A one-off event shouldn't trouble the DLM.
Message 2 of 4
(308 Views)
Re: Planned Restart
19-01-2013 12:00 PM
During the day, never at night is my rule of thumb. After I get up 7ish and no later than 6pm
FTTP 500 regrade from Tues 28th November
Message 3 of 4
(308 Views)
Re: Planned Restart
21-01-2013 10:55 AM
As mentioned, a one-off drop should not cause you any issues. If you wanted to be even more cautious you can login to your router and manually disconnect your session by clicking disconnect, and to reconnect just login and click connect.
Message 4 of 4
(308 Views)
