turn on suggestions
Pings
- Pings
Pings
Pings
05-12-2009 4:09 PM
I had a power out the other day , and re synced , and my ping has gone from 27ish to 35 ish. I was just wondering if it would be worth re syncing or gateway hopping , or is it just fluctuating naturally?
1 REPLY
Re: Pings
Re: Pings
05-12-2009 4:44 PM
I wouldn't resync, try a few more pings and at non busy times specifically, if there's no improvement, note which gateway you are on, and then try a hop.
