Pings
adamsh
Pings
Hi Guys,
Only recently moved back to Plusnet (3 days).
The first 2 days my Pings were excellent, averaging 9ms (just like my old plusnet days), however today I notice they have double and are between 20ms-24ms.
My old router is having issues where it keeps rebooting itself, unfortunatly my plusnet router has yet to arrive. is it possible inter-leaving has now been enabled on my line because of the router reboots?
I have been keeping a close eye on the errors over the last 3 days, and to be honest the router isnt reporting any errors at all (its a Zyxel 650HW), and my download speeds while slightly lower than my old Nildram speeds are still acceptable.
Thanks in advance for help.
James
Re: Pings
Hi Adam,
Chances are that interleaving was set to auto, and increased due to the drops in your connection.
I can place an order to remove it if you'd like me to do so.
adamsh
Re: Pings
Thanks for the reply James,
I opened a ticked yesterday and they have advised me they have put an order in and it should be back to normal by Tuesday.
davidhowell
Re: Pings
Can I get interleaving off also  please Smiley
Fixes: 92
Re: Pings
Quote from: davidhowell
I've placed an order for you that should complete at some point tomorrow Smiley
James
Re: Pings
Adam - I've placed your order too.
