Ping times... again...
- Ping times... again...
Re: Ping times... again...
28-01-2008 3:18 PM
Scott
28-01-2008 9:48 PM
Quote from: mcgurka looking at these results, it is quite possible.
Can you try pinging some networks like bbc.co.uk and google.co.uk?
This will get rid of the possibility that there may be some congestion problems with the other networks.
Scott
Hi Scott
are those okay?
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Michael>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.251.203] with 32 bytes of data:
Reply from 212.58.251.203: bytes=32 time=18ms TTL=248
Reply from 212.58.251.203: bytes=32 time=16ms TTL=248
Reply from 212.58.251.203: bytes=32 time=17ms TTL=248
Ping statistics for 212.58.251.203:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 16ms, Maximum = 18ms, Average = 17ms
C:\Users\Michael>ping google.co.uk
Pinging google.co.uk [216.239.59.104] with 32 bytes of data:
Reply from 216.239.59.104: bytes=32 time=36ms TTL=247
Reply from 216.239.59.104: bytes=32 time=41ms TTL=247
Reply from 216.239.59.104: bytes=32 time=29ms TTL=247
Reply from 216.239.59.104: bytes=32 time=33ms TTL=247
Ping statistics for 216.239.59.104:
Minimum = 29ms, Maximum = 41ms, Average = 34ms
puddy
28-01-2008 10:28 PM
Scott
29-01-2008 9:11 AM
Scott
29-01-2008 9:15 AM
29-01-2008 9:41 AM
A resync early this morning would tie in with interleaving being removed.
29-01-2008 10:05 AM
But Dscentral has been up and connected for 36hours now..
Do you reckon a reboot of the router would fix this up?
Scott
29-01-2008 10:37 AM
If it's already showing as being on the fast path, then it shouldn't be an issue. A few pings from your end would show whether or not you were seeing the benefits.
If you were not, just try to reboot your router.
29-01-2008 10:51 AM
Updated pings: Dock Street to Gardner Street NO VPN
Tracing route to gdst-term.core.dund.dscentral.co.uk
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms edst.core.dund.dscentral.co.uk
2 <1 ms <1 ms <1 ms edst-term.core.dund.dscentral.co.uk
3 20 ms 20 ms 22 ms lo0-plusnet.ptn-ag2.plus.net
4 20 ms 22 ms 20 ms ge0-0-0-204.ptn-gw02.plus.net
5 21 ms 22 ms 21 ms gi11-0-204.ptn-ag2.plus.net
6 41 ms 44 ms 44 ms gdst-term.core.dund.dscentral.co.uk
Now, the pings before were 40ms to first hop and 60ms to last at this time of day on the final hop. So commonly, I can take 20ms off all my ping times, which is what the results show.
But, if GS was fastpath, surely I wouldnt see the 40ms at last, since it was 60, take off the 20 for one connection, and you get 40? Am I wrong to think that 2 fastpath connections = 2 x latency discount?
I may be wrong!
Scott
29-01-2008 10:57 AM
Bear in mind your ping traffic practically needs a passport for it's travelling. It's got to go down to London and then back to Scotland again.
44ms from London to Scotland is pretty decent.
29-01-2008 11:38 AM
Problem is, the router I have in there at the moment (a rubbish Netgear) isnt actually showing me if its interleaved or not! hence my confusion
Scott
29-01-2008 1:37 PM
Probably the easiest is to download RouterStats
30-01-2008 12:08 AM
Pings are still sky high, Ive setup a trace to run every 5 mins, logging across the VPN and across the WAN.. I will collate the results tomorrow night. I got a little bothered when it took 28 seconds (not joking here) for a spoken word to get from my landline to my voip phone.. but only .5 second from voip to landline...
Scott
30-01-2008 10:54 AM
So much for that idea then. I'll certainly be interested to see the results of your traces.
30-01-2008 2:32 PM
