Ping times... again...
- Ping times... again...
Re: Ping times... again...
22-01-2008 5:18 PM
Will know for sure in about 2 hours.
Scott
22-01-2008 11:46 PM
Pings are better, but voip is still far from operable, averaging 150-175ms now.
Scott
23-01-2008 12:18 AM
23-01-2008 8:48 AM
Can you confirm that I wont loose my ip ranges, and if so, im happy to move to RIN.
Scott
23-01-2008 8:58 AM
You wouldn't *lose* your IP ranges, but they wouldn't work on the RIN platform. To move onto RIN (once we've set up your account, you would just log in as @plusdsl2.net instead of @plusdsl.net
The IP Ranges are completely different as it's BT Retails network rather than ours.
23-01-2008 9:18 AM
Scott
23-01-2008 9:20 AM
It's basically a troubleshooting measure to see if it is the actual connection itself that causing the problem.
23-01-2008 10:48 AM
Scott
23-01-2008 10:51 AM
23-01-2008 11:13 AM
Scott
Ive had a thought. Since my vpn gateways arent edge devices, RIN is going to wreak havoc with the ip addressing on the routers!
23-01-2008 3:24 PM
scott
23-01-2008 3:31 PM
Sorry forgot about this. Leave it with me and I'll try and get it sorted for you.
23-01-2008 3:31 PM
Scott
23-01-2008 3:37 PM
23-01-2008 3:40 PM
How long does the modify order/workplace mod usually take to apply?
Scott
