Ping & Upload prpblems - test please
robbo6
I am a very lucky guy who has had a stable ping of around 50 & upload of 0.35 for many years.  Last couple of days this has gone up to at least 250 (sometimes 100) & down to 0.1.  Downloads are "lumpy" but not the major problem.  Is it possible to test the line without going through the step by step checks (test socket is in an awkward place, no spare filters or alternative router (Bipac 7800N).  Trying to work from home but just unusable.  My username is roberts6
http://www.speedtest.net/my-result/3267703589
Many, many thanks
Dave
Fixes: 10
Re: Ping & Upload prpblems - test please
Could you post the information asked for here: http://community.plus.net/forum/index.php/topic,96155.0.html
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
robbo6
Jelv, apologies my frustration got to me.  Hope the following is what is required
1) Router stats
Status
ADSL Status
Parameters
DSP Firmware Version A2pB025f.d22k
DMT Status No Defect
Operational Mode ADSL2+
Upstream 444
Downstream 15447
SNR Margin(Upstream) 29.6
SNR Margin(Downstream) 3.3
Line Attenuation(Upstream) 14.3
Line Attenuation(Downstream) 25.5
2) BT Speedtest
1. Best Effort Test:  -provides background information.
Download  Speed
0.3 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.3 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 13.63 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.01 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.01Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
3) Current Line speed
Estimated line speed:
11Mb (This may vary between 6.5Mb and 15Mb) - Checked on 2014-01-28 21:18:38
Current line speed:
13.4 Mb
Dave
Fixes: 10
Everything looks right except for the actual speeds.
Are you connected to the router wired or wireless? If it's wireless could you repeat the speed test wired please.
As jelv says, it does all look correct (except for the speed test result) - though I've bumped your profile on our side from 13400 to 13600 to match the one on BTs side. We could do with uncapping the upstream as well, but that probably is best left until after the speed's improved - guessing a router reboot doesn't improve anything?
robbo6
Many thanks to you both for such a quick response.  A reboot sometimes appears to improve things for a while but no real difference today.  I will try the wired approach & report back (getting similar stats from several different wireless devices)
Dave
robbo6
Unfortunately wired made no difference
http://www.speedtest.net/my-result/3267869190
Is there anything else that can be done or do I need to get hold of a spare router ?
Dave
Probably worth testing with another one if you have one already or can borrow one, but don't go and buy a new one just to test with. Also though if you could go back to the BT speed tester and try to get invited in to perform the TAP3 test - you may need to run one more (TAP2) before it'll let you but with those results once TAP2 is done you should get invited to TAP3. Once we have those, please finish running through the wizard at http://faults.plus.net and paste those results into the comments box at the end (along with confirming you've run the TAP3 test) and our team will be able to get this sorted out for you.
robbo6
Logged on to the BT Speedtest through the speedtest@speedtest_domain logon (hopefully if I folowed the instructions correctly) I acheived much better result (although upstream still look appalling)
Download  Speed
11.4 Mbps
0 Mbps 21 Mbps
Download speedachieved during the test was - 11.4 Mbps
IP Profile for your line is - 13.44 Mbps
Upload Speed
0.01 Mbps
0 Mbps 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Back on usual logon, same problem as before ...
Dave
Fixes: 10
Matt, I know it doesn't make sense normally, but I'd be tempted to uncap the upload to see if that unlocks anything.
robbo6
Having played around & rebooted more times than is probably sensible, I can confirm that a reboot does sort the problem but only for about 60 seconds (during which time I get a ping & upload just like in the stable times).  Have borrowed a home hub 2 & filter from a friend & get the same results as with the Billion 7800N.  I have redone the BT Speedtest which shown below for the wired Home Hub, feels strange to me that BT Wholesale consider this upload speed acceptable
Download Speed
10.78 Mbps
0 Mbps 21 Mbps
Download speed achieved during the test was - 10.78 Mbps
IP Profile for your line is - 13.17 Mbps
Upload Speed
0.06 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.06Mbps
A dditional Information:
this time.
Please
Is there anything else that can be done ?
Many thanks in advance.
Dave
robbo6
Maybe I qas a tad hasty last night.  Whilst the BT Speedtester still shows an upload of 0.01 this morning my other speedtests are at normal levels http://www.speedtest.net/my-result/3271804274
Matt, would you mind uncapping my upload as suggested by Jelv & over  the next few days I wulll try & work put whether it has been the change of router or a mystry improvement in the line.
Dave
Sure, that's placed for you - it'll complete on Monday. Hope it helps.
robbo6
A further update.  Although everything appeared fixed on Friday morning, the performance soon deteriorated to the poor levels of the previous week.  However, this afternoon, following the uncapping of the upload speed, everything really does appear to be back to normal with the benefit of upload nearly at 1.00 rather than 0.35
http://www.speedtest.net/my-result/3279948532
Many thanks to Matt for uncapping & Jelv for being right !
Before the improvement today, I was about to start blaming the Avast anti virus as I had noticed that the iPad speedtest was consistently returning the "required" results where the laptops were not, however there now appears to be no need to investigate further (if it isn't broke don't fix it !)
