Ping Times
- Ping Times
- « Previous
- 1
- 2
- Next »
Re: Ping Times
06-07-2009 1:14 PM
James. Although there are four other devices that can connect to the router via wireless or ethernet cable, they haven't been on/connected during my tests.
Also I've tested while running just a browser in safe mode and then tested on a normally loaded session with a bittorrent client chugging away in the background (throttled back at my end to 10kb) and it seems marginally quicker on the normal session - as though it doesn't have to "wake-up" the line when it's already doing something.
Message 16 of 24
(682 Views)
Re: Ping Times
06-07-2009 1:17 PM
Thanks Ottmar.
Just to confirm, the device you were using to make the traceroute from, was not doing anything else?
Message 17 of 24
(682 Views)
Re: Ping Times
06-07-2009 1:22 PM
Previous msg edited
Message 18 of 24
(682 Views)
Re: Ping Times
11-07-2009 2:47 PM
I'm still seeing quite long ping replies. Has interleaving been turned off? Is there anywhere that I can check my interleaving status?
This is the best of three tests I did a few minutes ago:
[tt]Pinging bbc.co.uk [212.58.254.252] with 32 bytes of data:
Reply from 212.58.254.252: bytes=32 time=62ms TTL=249
Reply from 212.58.254.252: bytes=32 time=108ms TTL=249
Reply from 212.58.254.252: bytes=32 time=109ms TTL=249
Reply from 212.58.254.252: bytes=32 time=42ms TTL=249
Ping statistics for 212.58.254.252:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 42ms, Maximum = 109ms, Average = 80ms[/tt]
Message 19 of 24
(682 Views)
Re: Ping Times
13-07-2009 8:58 AM
This is the best of three at about 8:40am today
[tt]X:\>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.254.252]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 95 ms 76 ms 38 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 37 ms 37 ms 38 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 39 ms 38 ms 37 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 211 ms 207 ms 160 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 74 ms 66 ms 38 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 93 ms 211 ms 199 ms 212.58.238.133
8 70 ms 75 ms 39 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
9 43 ms 39 ms 38 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.[/tt]
Message 20 of 24
(682 Views)
Re: Ping Times
13-07-2009 9:37 AM
Hiya,
Interleaving is still set to automatic. Do you want me to turn it off for you?
Message 21 of 24
(682 Views)
Re: Ping Times
13-07-2009 12:15 PM
James, if you wouldn't mind - yes please.
Message 22 of 24
(682 Views)
Re: Ping Times
13-07-2009 12:23 PM
No problem - The order will complete tomorrow.
Message 23 of 24
(682 Views)
Re: Ping Times
16-07-2009 8:17 AM
Ping is now averaging 22ms.
Message 24 of 24
(682 Views)
- « Previous
- 1
- 2
- Next »
