turn on suggestions
Ping Noise etc
- Ping Noise etc
Ping Noise etc
Ping Noise etc
28-12-2012 8:04 PM
HI Guys,
Just wondering what sorta ping levels your seeing on the new unlimited service. And is it good for gaming?
really considering signing upto it.
Re: Ping Noise etc
Re: Ping Noise etc
28-12-2012 8:41 PM
Unless you are going from non-fibre to fibre your connection doesn't change so pings and speeds will be the same as you have now.
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
Re: Ping Noise etc
Re: Ping Noise etc
28-12-2012 8:52 PM
You say that. but when i was with Opal. my pings where from 16-28 but now with sky there mid 30's, Hoping to move to PN once this is confirmed. And Sky are slowing down the line. carnt tell if interleaving is on or not.
and btw it's an adsl connection. Here is the stats FYI
Re: Ping Noise etc
Re: Ping Noise etc
29-12-2012 11:58 PM
even if your ping does improve
your gonna get penalised by some game servers with lag compensation.
at my wits end with fifa.
my connection seems to degenerate after starting the first game.
it may not even be them though.
remember years ago when adsl+ came out and my gaming went downhill with variable ping.moved back to a lower download and things returned for the better.....ping levels were around the same.
could be that my router cant handle fibre over 40mb
because it seemed really good before i moved upto the higher limits.
