Pick any number you want lol
thisoldman
This evening between 5.45.and 6.15 to pass the time , i ran some speed tests. here  are the results
mybroadbandspeed        7300, 5723,8903,7843,5659 4572
speedtestnet                      4752,5340,5680,5500,5300,5672
bbandspeedckr                  5680,5712,5660,5412,5720,5666
So what is my real/true  d/l speed  ....................or is it the case of  pick any number you want?
MJN
Re: Pick any number you want lol
As odd as it may sound, the answer really is 'all of them, and none of them'.
Any measure of throughput can only ever be an instantaneous measurement which is affected by many other variables such as congestion, faults, traffic shaping, inadequencies of measurement methods, etc. The potential for variation is therefore entirely to be expected. The impact of this variance can only really be reduced through repeated tests and simply taking a mean average although of course it will only give you something of a ballpark figure, but this often sufficient for many (most?) situations.
Mathew
thisoldman
thanks for your reply mathew.  The 8903 from mybroadbandspped made me laugh (is that the  right word?) as my exchange has a max of 8mb and im 1.5 miles away.
As alice said to humpty  dumpty    " a word/  download speed means what i want it to mean , nothing more, nothing less."
MJN
That's probably a very good way of looking at it!  Grin
thisoldman
Huh
19.02pm                        mybroadbandspeed              11.2mb
                                        speedtest.net                            5.3mb
                                        bbspeedchk                                4.7mb
at the moment this is purely amusing me  but tomorrow i may not be in the same  frame of mind
Fixes: 58
Which security package are you using
thisoldman
hello oldjim    im using  mcafee intenet sec suite.
oh by the way  do you by any chance know why the new version of ccleaner has included mcafee antivirus in its application cleans
Fixes: 58
The reason for asking is that some security packages really muck up mybroadbandspeed such as Kaspersky.
I haven't heard of McAfee doing that but you should try running the test with it disabled
Assuming you are saying that ccleaner takes out some of the McAfee entrries I can only think that is has as low opinion of McAfee as myself
http://forum.piriform.com/index.php?showtopic=16403
Infinity
Quote from: thisoldman
Huh
                                        speedtest.net                             5.3mb
                                        bbspeedchk                                4.7mb
My Broadband Speed 16.678mb
Speedtest net 16.71mb
