Photobox problems and Plusnet
- Photobox problems and Plusnet
16-10-2008 9:17 PM
Re: Photobox problems and Plusnet
16-10-2008 9:54 PM
Quote They're now saying it's because I'm with Plusnet and that it's an ISP (Tiscali/Pipex) problem.
I'm not sure how it can be a problem with us if it's a Tiscali/Pipex issue, have they clarified that at all?
See if a traceroute shows up any bottlenecks perhaps, if not then a wireshark capture might work at least to see how the traffic's being classified.
16-10-2008 10:15 PM
16-10-2008 11:46 PM
Can you describe your problems in a little more detail?
17-10-2008 9:13 AM
Quote I read on Photobox that Pnet is owned by Tiscali, hence the problems. I thought Pnet was bought out by BT - so are they right?
Plusnet is indeed owned by BT retail, though Tiscali don't come into the equation anywhere (except as Bob mentioned we have some customers provisioned on Tiscali LLU products). BT retail and Tiscali are two very separate companies.
17-10-2008 10:31 AM
B.
17-10-2008 6:22 PM
I have been creating calendars on Photobox - you upload your pix and then load up the Photobox calendar software to sort the pix into what you want.
http://www.photobox.co.uk/shop/calendars-and-diaries
This has been working fine until a few days ago - now I just can't load up the calendar pages at all! I get an error message saying the browser journey cannot be completed (or similar). I have now tried in Firefox, IE6 and Safari. Same problem. I'm using Windows XP on a PC. I also tried to load up the same calendar software with my OH's laptop (IE7/XP) - same problem!!
I've tried clearing my internet cache and cookies (suggested by Pbox), but to no avail.
Pbox are saying it's an ISP issue. In a new email reply to me they say: "Unfortunately Plusnet use the same communications infrastructure as Tiscali. Please contact Plusnet as this is an ISP issue. You will probably find that while Photobox creation software is not working, other applications like the BBC iplayer are also affected." ... Actually I am able to access BBC IPlayer, so that's wrong.
Does anyone have any ideas - anything in particular I need to ask Pbox? Any other details you need from me? I'd really like to have this sorted.
Thanks all.
18-10-2008 12:32 PM
I'm getting the exact same problem and response from Photobox. I've tried Firefox 3, IE7, Opera9 and Chrome on both XP and Vista as well as updating flash etc.
I'm heading out to borrow a friends connection using a different ISP, I'll report back with what happened.
19-10-2008 8:43 AM
Meantime, I have had the following fresh response from Pbox if anyone can comment on this (BTW, I just tried loading the calendars and it's 8.30am - same problem, won't load):
"I believe PlusNet is a wholesale service using the ADSL Tiscali Local Loop Unbundling (LLU). I will be very surprise if the traffic-shaping techniques during peak times restricting the move of certain type of data is not the same for customers like yourself.
They might be using what is known as Deep Packet Inspection, or DPI, to filter the types of data moving across their Internet bandwidth. Tiscali is then restricting the movements of certain types of data. This causes the connection to drop for small periods of time and disconnect the creator software.
This can be easily demonstrated by analysing the router/ modem stats of the session.
No change has taken place in the Creator software in the last month or so to cause such a significant behaviour.
Did you try using the creator software before 4.00pm? Do you have the same behaviour on the site?
At the moment our team is looking for a fix but if you can use the service outside peak times (5.00-10.00pm) it could work."
19-10-2008 9:00 AM
19-10-2008 12:17 PM
From the sounds of it a wireshark capture would be a good idea - that way we can see how the traffic is being classified and give you some ammo for a reply. There's details on how to do a wireshark capture here - you should do this when you're attempting an upload to pbox.
Hope that helps,
19-10-2008 1:31 PM
19-10-2008 3:08 PM
19-10-2008 4:08 PM
19-10-2008 6:40 PM
