turn on suggestions
Phones and SN Margins
- Phones and SN Margins
28-03-2012 1:29 PM
When my SN margin is a bit up and down I find lifting the receiver on my phone for a few seconds generally shifts it from the bottom of its range back up to the top, ie a rise of about 3 or 4 dB. Doesn't always work but has done 3 times out of 3 this morning. Just wondered if this is odd or does it work for other people too?
Re: Phones and SN Margins
28-03-2012 2:57 PM
I'd say it was worth changing your filter and plug into the test socket and see what happens
29-03-2012 10:42 PM
If he plugs into the test socket direct, then he won't be able to see if lifting and cradling the phone affects the SNR........
Kevin.
29-03-2012 11:04 PM
Yes he will - you plug a filter into the test socket into which you can plug the router and the phone
30-03-2012 10:53 AM
But it might be his filter that is causing the problem!
Kevin.
30-03-2012 10:55 AM
Did you miss reply #1?
30-03-2012 2:08 PM
No.
(But I did forget....)
Kevin.
