Phone line was dead, now working now ADSL slow
- Re: Phone line was dead, now working now ADSL slow
29-09-2015 5:10 PM
I posted something simialr to this on the phone forum, but this is more of an ADSL issue
After five days the phone finaly started working again
however my broadband speed is significantly lower than it was, currently getting speeds of 5.5- 6.5meg on the various speed tests
router says
Upstream / Downstream
Current Rate (Kbps) 960up, 7808 down
Max Rate (Kbps) 1096up, 8352 down
SNR Margin (db) 8 up, 6 down
Line Attenuation (db) 12.5up, 27 down
Errors (Pkts) 0 0 up, 0 down
Plusnet line speed thing https://www.plus.net/my.h...ction=data_transfer_speed says:
Estimated line speed:
11Mb (This may vary between 10Mb and 13.5Mb) - Checked on 2015-07-17 23:29:17
Current line speed:
6.7 Mb
BT speedtest says:
Download speed achieved during the test was - 6.56 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 6.89 Mbps
Upload speed achieved during the test was - 0.78Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Also my plusnet voip service isnt working, although its something that I hardly use
29-09-2015 7:06 PM
29-09-2015 7:15 PM
Line Status: DSL Connected
DSL Modulation Type: ADSL_G.dmt
Annex Type: Annex A/I/J/L/M
29-09-2015 7:20 PM
29-09-2015 10:14 PM
DSL Modulation Type: ADSL_2plus
Upstream/Downstream
Current Rate (Kbps) 1059 / 10606
Max Rate (Kbps) 1068 / 11652
SNR Margin (db) 6.4 / 6
Line Attenuation (db) 12.3 / 26
Errors (Pkts) 0 / 0
BT speedtest
Download speedachieved during the test was - 6.32 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 9.36 Mbps
Upload speed achieved during the test was - 0.87Mbps
30-09-2015 8:24 AM
Keep an eye on it and if it doesnt return to the speeds you were getting perhaps try a daytime reboot at the weekend.
30-09-2015 8:25 AM
You also need to check that the PlusNET profile has also updated. See the current speed link below. Based on the BT speed test profile, it should be 9.3Mbps.
If it has updated do another BT speed test. If that produces the same result as above, try dropping the connection (PPP session) through the router interface. Then run the speed test again.
02-10-2015 1:30 PM
Download speedachieved during the test was - 8.82 Mbps
Upload speed achieved during the test was - 0.91Mbps
My speed's have been dropping over time, and each time I've run the speedtest the IP profile has also been dropping as well over time, At one point in the past it was over 12Mbps ( could even have been 13-15)
on the plus side, since the fault was eventually repaired on the phone the crackling has stopped on the line
07-10-2015 5:11 PM
Router Stats
Current Rate (Kbps) 104 / 10432
Max Rate (Kbps) 1040 / 11384
Errors (Pkts) 0 / 0
BT speed Test
Download speedachieved during the test was - 8.86 Mbps
IP Profile for your line is - 9.2 Mbps
plusnet speed check page
Estimated line speed: 11Mb (This may vary between 10Mb and 13.5Mb) - Checked on 2015-07-17 23:29:17
Current line speed: 9.2 Mb
Kitz speed estimate http://www.kitz.co.uk/adsl/max_speed_calc.php ; says
line length 1.9km
BT21cn WBC&ADSL2+ 17600 kbs, IP profile 15523
07-10-2015 7:42 PM
07-10-2015 11:13 PM
10-10-2015 6:45 PM
11-10-2015 10:54 PM
Nothing much
router stats still the same
BT speedtest
Download speedachieved during the test was - 8.83 Mbps
IP Profile for your line is - 9.49 Mbps
Upload speed achieved during the test was - 0.86Mbps
Plusnet line speed
Current line speed:
9.4 Mb
Another annoying thing is that after 5 days of no voice line, theres been no apology nothing - the only communication sent was a dry the fault on your phone line has now been fixed
13-10-2015 11:33 PM
15-10-2015 8:09 PM
router stats still the same, and after reading another post on here i tried a few tracert commands in command...
Tracing route to ntp.plus.net [212.159.6.10]
over a maximum of 30 hops:
1 3 ms 3 ms 3 ms 192.168.1.1
2 192.168.1.113 reports: Destination host unreachable.
Trace complete.
tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.2]
2 22 ms 19 ms 18 ms lo0.10.Central10.ptw-bng02.plus.net [195.166.130.203]
3 19 ms 18 ms 19 ms irb.10.PTW-CR02.plus.net [84.93.249.2]
4 19 ms 19 ms 20 ms ae2.ptw-cr01.plus.net [195.166.129.4]
5 192.168.1.113 reports: Destination host unreachable.
Trace complete.
C:\Users\
C:\Users>tracert www.google.co.uk
Tracing route to www.google.co.uk [216.58.210.35]
1 4 ms 3 ms 3 ms 192.168.1.1
2 19 ms 18 ms 18 ms lo0.10.Central10.ptw-bng02.plus.net [195.166.130.203]
3 20 ms 19 ms 19 ms irb.10.PTW-CR02.plus.net [84.93.249.2]
4 20 ms 19 ms 19 ms 72.14.223.32
Trace complete.
