Phone affecting speed
- Re: Phone affecting speed
23-06-2014 10:37 AM
Quick history. Having intermittent noise problems with phone. Went through a process of trying different filters, a wired phone and so on, trying to isolate the cause. Eventually a BT engineer was despatched and he decided to change the socket, upgrading me to a modern socket. To my relief this cured the noise problem.
However while doing the testing I notice the connection speed the modem sets is dependent on the filter I use and the phone (This is backed up by subsequent speed test - speed range 7.5 to 9.5 Mbps). The filter is easy to sort, I use the best one (I had 3 to try). The phone is not so easy to sort as I get the best performance with a wired one but I obviously prefer suing my wireless one (as there are several units around the house).
Any one else see this?
Any one else recommend a phone that does not affect the connection speed?
S
S
Message 1 of 4
(735 Views)
3 REPLIES 3
23-06-2014 12:29 PM
Message 2 of 4
(478 Views)
25-06-2014 9:58 AM
Thanks for the info. Adam,
Now I look at it again I realise that the big improvement I made, aside from the new main socket, was using the best filter I had. The difference between the phones is 8.5 Mbps to 9.5 Mbps and I can live with that. Rather than change the phone, or lose some of the flexibility. On top of which choosing a phone is a bit of a nightmare.
Thanks again S
Thanks again S
Message 3 of 4
(478 Views)
25-06-2014 10:15 AM
You might try using two filters with the cordless phone. Until I did that I was getting disconnections every couple of days, but once I plugged in the second one my line would stay up for months at a time. (I suppose it's possible that the first one was bad and just swapping them would have had the same effect, but why mess with success?)
Message 4 of 4
(478 Views)
