Philips CKA5720 Wirelss Router
- Philips CKA5720 Wirelss Router
30-08-2008 1:15 PM
All
In my infinite wisdom (!) I decided to replace my old BT Voyager 1250 (b) wireless router with a Philips CKA5720 (g) wireless router.
Unfortunately I cannot seem to get the Philips to even see the ADSL line coming into the house. Does anyone have a link/settings that explicitly tell me what the router and Plus net are expecting each other to see ?
I've spent ages messing about with PPoE and MTU and "stuff" and am at a point where confusion is just about absolute!
I'm setting it (I think!) to :-
PPoE
G-DMT
1492
0-38
and my Plus net userid & pass
Is there anything glaringly obvious that I'm missing?
Thanks in advance
Pat
PPoE
G-DMT
1492
0-38
Thanks in advance
Pat
Message 1 of 3
(1,364 Views)
2 REPLIES 2
Re: Philips CKA5720 Wirelss Router
30-08-2008 1:56 PM
Try PPoA
MTU might be better at 1500
Good Luck
Good Luck
Message 2 of 3
(418 Views)
30-08-2008 3:54 PM
Got it to work finally;
VPI/VCI - 0/38
Encap - LLC
Protocol - PPPoA
I'll try changing the MTU later, once I'm confiident that all is ok!
(Best bit of aadvice I think is patience - once you try something give it a few to "settle down" so to speak)
Pat
VPI/VCI - 0/38
Encap - LLC
Protocol - PPPoA
Pat
Message 3 of 3
(418 Views)
