Perplexing Problem
solidus
Perplexing Problem
Perplexing Problem
I have a netgear DG8234g router connected by ethernet cable to my desktop
computer which  I dual boot either windows XP or Linux.I cannot connect to the internet when in windows xp even with the firewall disabled.I can however connect perfectly when booted into Linux.
Further I have a wireless linked laptop running windows vista which also connects perfectly.
I would like to solve this problem with windows xp.
Thanks for  any help.
Regards
I have had no trouble with my previous providers and have just got this problem since moving to plusnet.
4 REPLIES 4
jelv
Fixes: 10
Re: Perplexing Problem
Have you checked you have the correct IP address, mask and gateway set in XP?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Peter_Vaughan
Check Windows TCP/IP is set to obtain IP automatically.
Verify settings in a dos box with ipconfig/all. Gateway should be your router and IP should be similar to the router with the last number different
notheruser
Just to add to Peter's post - also check DNS points to the router, or to PlusNet DNS servers
solidus
Thanks  to all your advice cured the problem.
The help was very much appreciated.
Cheers
solidus
