Periodic disconnects
- Periodic disconnects
06-01-2010 7:10 PM
I've been experiencing periodic disconnects for more than a week. I think it's losing the ADSL Sync, and it usually comes back in a minute or so. It can happen every few minutes, but sometimes there are no problems for hours. As my son plays MW2 online, the disconnects are a real pain - fortunately he's been patient. I raised a ticket - 31345312 - but nobody seems to be looking at it.
I've been with Plusnet for four or five years, and this is the first time I've had problems. They seem to coincide with a request to switch from Broadband Your Way to Premium - I think that can trigger an upgrade to ADSL2+, so maybe that's the problem. I've tried unplugging the phone, I removed an unused extension, I've reset the router to factory settings, I've tried two filters. Can anybody suggest anything else?
Thanks, Roger
Thanks, Roger
Message 1 of 8
(1,527 Views)
7 REPLIES 7
Re: Periodic disconnects
06-01-2010 10:16 PM
I am experiencing the exact same problem. Been with plusnet for years, no apparent problems then approx a month ago getting the random drops. I have also switched from a monthly contract to Premium. MW2 is unplayable in this state, I can never finish a match.
Message 2 of 8
(673 Views)
06-01-2010 10:21 PM
Both of you:
Can you run the BT speed test and see what speed it says for your IP Profile. Then go to https://portal.plus.net/my.html?action=data_transfer_speed and see what it says for your current line speed. It should be the same. As you've changed accounts I fear the speed on the portal may say 2000 irrespective of your IP Profile. If that is the case ring support and ask for it to be corrected.
It may not be the cause of your problems, but it won't be helping if it is wrong.
Message 3 of 8
(673 Views)
08-01-2010 8:16 AM
The BT test reports:
Download speedachieved during the test was - 5967 Kbps
Additional Information:
Your DSL Connection Rate :9723 Kbps(DOWN-STREAM), 445 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
The other page says:
Current line speed:
7150
Current line speed:
7150
Message 4 of 8
(673 Views)
08-01-2010 10:14 AM
You have been switched to ADSL2+ - it looks like it's still trying to find the right speed for your line.
Message 5 of 8
(673 Views)
08-01-2010 6:17 PM
Thanks jelv. I think previously the IP profile was 8000, so maybe as it slows down it will get more reliable.
Regards
Regards
Message 6 of 8
(673 Views)
08-01-2010 6:40 PM
The maximum IP Profile on ADSL1 is 7150
Message 7 of 8
(674 Views)
26-03-2010 10:09 PM
I discovered that a new version of the firmware in my router had been published about a year ago - once I installed that, I didn't get the disconnects any more.
Thanks for everybody's help, including customer support.
Message 8 of 8
(674 Views)
