Performance of the Technicolour tg582n Router
- Performance of the Technicolour tg582n Router
10-08-2012 12:10 AM
I have just received the Technicolour tg582n router as an upgrade to my old Thomson tg585v7.
The reason I wanted an upgrade was that the RAW file sizes of my new camera and are now about 25MB. Transferring several GB of photos from my laptop to my Desktop is taking longer and longer.
The Thomson ran the 802.11g protocol with speeds up to 56Mbps, with actual speed of 24Mbps (according to the router)
The Technicolour tg582n runs the newer faster 802.11n protocol, which I thought enabled speeds up to 300Mbps.
However the router is only reporting an actual speed of 65Mbps.
I now don't have any 802.11g devices. My Laptop is less than a year old, and uses the 802.11n protocol, but only has a 100Mbps Ethernet adapter. I have one other PC that also uses the 802.11n protocol and my Desktop which has a Gigabit Ethernet connection, though of course the router is only 100Mbps Ethernet enabled.
I had hoped to be able to get at least 100Mbps from the wireless connection
Is this 65Mbps in fact as fast as the TG582n performs or is there anything I can do to speed things up (other than disable wireless and use an Ethernet cable between laptop and desktop)
65Mbps is about 2.7 times faster than the old router, so it is an improvement, but if 65Mbps is the max throughput then can anyone recommend a good router that has a Gigabit Ethernet connection and much faster wireless ability.
Thanks for your help
Re: Performance of the Technicolour tg582n Router
10-08-2012 2:48 AM
11-08-2012 8:26 PM
Sorry I obviously didn't explain the situation very well.
My point really was that the new Plusnet Technicolor router was meant to be a faster router then the old Thomson using the newer 802.11n protocol.
I wasn't trying to connect the wireless laptop to the other wireless PC , but to transfer large files from the laptop to the Desktop (which is attached by Ethernet to the router).
The old Thomson was transferring at the rate of 24 Mbps (Mega Bits Per Second. 3 Mega Bytes per second) so 16 GB of RAW files (about 600 photo) used to take about 1 and a half hours to transfer.
The so called improved performance of the Technicolor was originally 65 Mbps when I set it up (8 Mega Bytes per second) but today it is down to between 26 Mbps and 39 Mbps. Why ?
I wanted to know why the transfer speed/rate was so poor on a 802.11n protocol router when I have no slower 802.11g devices or below in the house.
I appreciate I can always put in a CAT5e Ethernet crossover cable between my Desktop and laptop, disable the laptops wireless adapter, enable the Ethernet adapter on the laptop, create static IP addresses on both machines and get transfer speeds of 100MBps, which is what I did before. What I was hoping was that the new Technicolor tg582n router would be good enough so that I could avoid all of that and achieve 100Mbps transfers through the router.
As it stands the Technicolor tg582n router does not to seem to be able to get anywhere near 100Mbps, unless it can be tweaked in some way I'm unaware of.
So my upgrade has locked me into Plusnet for another year, which is not a problem, I would have stayed anyway, but it still leaves me with a problem of low transfer speeds between a wireless laptop and my Desktop PC, which is why I asked if anyone could recommend a faster Wireless router which also had at least one 1 Gigabit Ethernet port.
11-08-2012 8:41 PM
12-08-2012 12:36 PM
12-08-2012 1:10 PM
Another thing to consider is that some wireless cards have asymmetric download and upload bandwidth, e.g. the Intel 5100 is "1x2", so although it can receive at 300 Mbps it can only transmit at 150 Mbps (receive at 130 and transmit at 65 without using 2 channels).
07-01-2015 10:53 AM
Quote from: Slapdash Hi,
I had a Thomson (pre-fibre) then was sent a Netgear N150 for fibre - which I thought ridiculous when it actually says on their website (and on the bnox) that it isn't suitable for streaming media. So upon renewal of contract recently I asked for the latest router offering, paid my postage and waited.
I saw the order come up and then did a search for the "technicolour TG582n" - I saw this thread and this: http://www.trustedreviews.com/plusnet-fibre-router-review#tr-review-summary
- So I've cancelled it! it looks like I'd have probably been worse off and £5 lighter! Going to see if I can get myself a decent one in the sales.
07-01-2015 11:10 AM
07-01-2015 12:04 PM
http://npr.me.uk/telnet.html#w300
With the OP's ethernet card only being 100Mbps I think it's very likely the laptop wireless card will be only "1x2" as explained by ejs.
It's often very easy to replace the wireless card in a laptop, just remove a panel from underneath and there it is. -- check if your laptop takes a half card or full card.
I can recommend a "intel 6200 AGN", you can pick them up for £15 or less from ebay.
01-08-2015 3:57 PM
01-08-2015 7:54 PM
The above link explains what they do and how to use them.
