Performance issue - intermittant poor RTT to first Plus Net hop
- Performance issue - intermittant poor RTT to first...
26-09-2015 7:34 PM
First get the formalities out of the way. It's a DSL "Max" type service, same as were have had with a previous provider on this same line for around 4 years. Answers to the fundamental questions ..
1. Line status info ...
[tt] --- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 0/38
DSL Status: Showtime
DSL Mode: G.DMT
DSL Channel:
DSL Upstream Rate: 448 Kbps
DSL Downstream Rate: 4160 Kbps
Down up
DSL Noise Margin: 5.5 dB 18.0 dB
DSL Attenuation: 56.0 dB 31.5 dB
DSL Transmit Power: 19.3 dBm 12.3 dBm
[/tt]
Synch speed is pretty much as good as it gets here, our line is over 5km and clearly not top notch.
2. BTW speed tester returns an error Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
3. Line speed from Plus Net account page = 3.0meg
All tests carried out with host connected by Ethernet flying lead direct to router, microfilter connected to BT test jack socket, different microfilters tried.
With that background let me explain the fault. The fault is intermittant episodes of very high latency, 800 to 1000ms RTT rather than the normal 30-40ms. This shows at the first hop after our premises into the Plus Net network, for example ...
[tt] Tracing route to relay.plus.net [212.159.9.107] over a maximum of 30 hops:
1 3 ms 3 ms 3 ms 192.168.1.1
2 927 ms 941 ms 935 ms lo0-central10.ptw-ag03.plus.net [195.166.128.197]
3 935 ms 915 ms 913 ms link-a-central10.ptw-gw01.plus.net [212.159.2.152]
4 885 ms 912 ms 910 ms xe-4-3-0.ptw-cr01.plus.net [212.159.0.244]
5 948 ms 909 ms 913 ms ae1.pcl-cr01.plus.net [195.166.129.1]
6 971 ms 916 ms 914 ms po2.pcl-gw01.plus.net [195.166.129.41]
7 955 ms 974 ms 973 ms gi5-8.ptp-cr01.plus.net [84.93.224.48]
8 951 ms 990 ms 975 ms vlan2657.ptp-elb01.plus.net [84.93.224.36]
9 949 ms 972 ms 947 ms relay.plus.net [212.159.9.107]
[/tt]
The excessive RTT is unrelated to normal use on the circuit, with one oddity. If I run a speed test or other bulk data transfer during one of these episodes, then while that test is running the ping RTTs drop to a normal 30-40ms during the actual transfer, then go back to 800-1000ms immediately the transfer ends.
When first reported Plus Net tweaked our target noise margin, and enable interleaving, neither of which stopped the problem recurring.
Any ideas?
Thanks, Tony S
Re: Performance issue - intermittant poor RTT to first Plus Net hop
27-09-2015 8:30 AM
Can you please set up a TBB BQM? Not having a static IP address will make loss of PPP (new IP address) tedious, but it will enable you to visualise latency and packet loss. This requires ping response on WAN to be enabled, so I do hope you are not using the 2704n router?
Kevin
27-09-2015 9:33 AM
(Obsolete TTB removed)
I've set up some monitors with PRTG from inside the network, logging ping times to smtp.plus.net as well as to two Open DNS servers. Can you suggest the best Plus Net host for me to use? I want something that should always have a decent response within their network, ideally I'd use the first hop but that's subject to change with my IP address. Annoyingly neither of the two routers I have to hand support SNMP, ideally I'd have a plot of ping time vs utilisation to confirm that it's not our load that's dragging the response down.
27-09-2015 9:51 AM
27-09-2015 10:09 AM
http://www.thinkbroadband.com/ping/share/9ef826fc108476a09683ac050c479f43.html
27-09-2015 10:18 AM
David
27-09-2015 12:21 PM
27-09-2015 12:46 PM
27-09-2015 1:16 PM
In answer to an earlier (now irrelevant) question - PlusNET only changes your dynamic IP address after either end has dropped the PPP session.
27-09-2015 5:43 PM
Nothing much more I can do now, this fault has been logged Plus Net since 3rd September, but this Wed we had a minor fault on the copper line, and now PN have the call on hold till next weekend.
28-09-2015 7:35 PM
