Peak time jitter increased and now some congestion
- Peak time jitter increased and now some congestion...
02-01-2014 9:38 PM
For the past few nights the peak time jitter on the BQM Has shown an increase compared to what it has been in recent months, also more disappointingly throughput speeds have also seen a reduction this is ONLY during peak times my throughput is being throttled back by around 10mbit sometimes more Depending on Gateway I won't enter into raising a fault because doing so will not resolve this, This i believe is another network imbalance if not a congestion issue the fact that this only occurs during peak times points to other than my connection from Cab to my home Oh and this only started on 27/12/13 So please check all historic data there you may find a possible cause for what I'm experiencing (which IMO i should not be )
Message 1 of 4
(674 Views)
3 REPLIES 3
Re: Peak time jitter increased and now some congestion
03-01-2014 10:25 AM
Hi deathtrap, as I posted on your other thread Dave's back on Monday so I'll ask him where we are with this then and make sure things get picked up for you.
Message 2 of 4
(373 Views)
03-01-2014 1:27 PM
Thanks Matt ,But there are 2 separate unconnected issues here this peak time issue has only been evident for the past few days
Message 3 of 4
(373 Views)
03-01-2014 1:34 PM
That's fine, but as this one involves higher pings and possible congestion I'm still going to have to refer it to Dave as he's our resident expert in those areas.
Message 4 of 4
(373 Views)
