Peak time Sheffield Mosborough exchange problems again ?
Justin7
Internet connection speeds dropping from 70mb to around 7mb at peak times in the evenings, has anyone else noticed?
This happened a while ago and was down to a BTw issue that was fixed - thinking it may have reoccurred again...
(Question #77215528 )
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Peak time Sheffield Mosborough exchange problems again ?
Did this only happen last night or has this been the case for a few nights now?
Chris Pettitt
Cloud Environments Engineer
Justin7
Hi Chris, thanks for your prompt reply.  It has been happening the last few nights this week, but particularly slow yesterday.  Is there any obvious reason for this you can see ?
Plusnet Staff
Plusnet Staff
Fixes: 5
Not that I can see, but obviously doesn't mean it isn't happening of course Smiley
I can see a few other threads regarding a similar issue at different exchanges so I'll have a look at those too.
Chris Pettitt
Justin7
Ok, thanks Chris. I appreciate you looking into this.   Smiley
I noted a few peak time slowness threads lately too, but thought the symptoms here were very similar to the problem before as just like before the up stream seems fine , just the download speed and ping affected.
I look forward to your findings...
Thanks for your help.
Justin7
Any update available on this yet ?  Smiley
I have been contacted by support desk but they seem to be sending me round in a loop!!
Is anyone there able to move this on, as I have followed all the troubleshooting steps they need me to do again ?!  (ref #81962819)
Plusnet Staff
Plusnet Staff
Fixes: 5
Nothing at the moment I'm afraid.
Do you have a Ping Graph at all? http://community.plus.net/forum/index.php/topic,106312.0.html
This will help us keep an eye on your connection over the weekend.
Chris Pettitt
Justin7
The problem appears to be over now, very odd. The slowdown that was particularly bad wednesday and thursday hasn't reoccured thankfully. Not sure what that was all about but I'm pleased that it's ok again now!!    Smiley
Thanks for all the help, it's good to know the support at Plusnet is there when we need it!
Plusnet Alumni (retired) LinnPlusnet
Not a problem Justin7! If the problem appears again please do let us know!
Justin7
It looks like problems have re occurred again tonight.
Ping times increased from 13 to 130.
Download decreased from 72 to 6.
Anyone know what's causing this, I have checked my equipment, wired bt speedtest, etc.
Looks like peak time congestion.
Fixes: 95
Looks like a few people had problems in Sheffield last night, myself included:
Interestingly, my BT Retail line looks fine for the same period Huh
Justin7
Well I thought this seemed like a Plusnet or systems issue rather than just my connection.
Any news on the cause / solution ?
Fixes: 95
Another thread here. Fairly confident it will be a problem across the Wholesale platform given its geographic nature.
BT Retail use a different Wholesale platform to us IIRC.
Justin7
Thanks for the updates Bob, reassuring to see its not just my connection.
Appears okay tonight so far.    Smiley
Fixes: 95
For some maybe Wink
