Paying For My Daughters ADSL?
- Paying For My Daughters ADSL?
30-12-2014 6:23 PM
Is this possible with plusnet?
Thanks.
Re: Paying For My Daughters ADSL?
30-12-2014 6:27 PM
The next question is whether you can set up broadband on the boyfriends phone line which I think is possible providing it is a BT line
However that will be more expensive as the phone won't be with Plusnet
30-12-2014 6:47 PM
30-12-2014 8:21 PM
31-12-2014 9:33 AM
31-12-2014 10:09 AM
31-12-2014 2:41 PM
Thx
31-12-2014 3:32 PM
In regards to blocking calls, we do not have this facility. However, you can ask to implement a credit limit as low as £5 a month on the account once it has gone live.
If you have any more queries do not hesitate to fire away.
31-12-2014 4:11 PM
Is my memory failing me or has flexibility changed - IIRC out going call restrictions (BT Call Barring) has been provided in the past on a case by case basis. It needs manual processing, but given that this is essentially a "BT" line, it ought to be possible (I did not say commercially practical) to get any BT service enabled.
Boodz,
One other approach to this is to get a DECT phone system which blocks numbers starting 09 / 07 etc. Panasonic call this "Call Restriction" which should not be confused with "Call Blocking" or "Call Barring" which tends to refer to "managing" unwanted inbound calls.
See - http://www.pmctelecom.co.uk/shop/dect-multiple-handset-with-answering-machine/panasonic-kxtg8062eb-t...
There are also other devices - see http://www.amazon.co.uk/999-Call-Blocker-Restrict-Outgoing/dp/B00C81AIHY/ref=sr_1_fkmr0_2?ie=UTF8&qi... - though the £90 price tag is a bit steep.
31-12-2014 4:19 PM
31-12-2014 4:29 PM
@Townman - In this situation, it's not something that we could offer and even on a case by case basis, it's extremely rare that we would apply the restriction on the line.
@Oldjim - True. It's not the best of ideas however it is a way to manage how outbound calls are used.
I understand it's quite a frustrating situation, especially when a landline may only be used for a broadband service however apart from applying a low call credit limit, there is little that can be done.
If anyone has any further suggestions, please feel free to chip in.
31-12-2014 4:45 PM
Your reply invites the question "In what situation might you offer this service on a case by case basis and what are those 'extremely rare' circumstances where PlusNet would apply restrictions to the line?".
Outbound call barring is a telephony service provided on BTOR equipment - if there is customer demand for this service option, why does PlusNet not offer it as either a standard service or by special request? Such a service is especially important where there is a clear need to facilitate a communication capability with an understandable need to limit cost liability. In most situations one might well expect a subscriber to be self disciplined and to accept full responsibility for their actions. I think the OP has presented a situation here were such normal considerations are not reasonable and other solutions (as provided by other CP retailers) are required.
31-12-2014 4:47 PM
You then need to decide whether it is more economical to get the broadband from them as well as you won't get any discounts from Plusnet and will get hit with a £2.50 per month extra charge
31-12-2014 5:31 PM
Though we do operate on the BT Network, we don't offer all of the services that are available on the network or that BT Retail may provide.
I can't offer a reason as to why Plusnet don't offer this service I'm afraid. We may offer this service on a temporary basis should the line be faulty etc and there is an extensive repair time, but in this situation, the restriction wouldn't be applied.
I understand it can be frustrating however there are other alternatives to prevent high call charges such as a lower credit limit or maybe a pin locked phone.
We've explained to the OP why we cannot offer the service and should they have any further concerns regarding this, they can contact us.
31-12-2014 5:51 PM
Two final questions...
1. Are we talking about the same thing here? Outbound call blocking to specified numbers or area codes (e.g. 09xx and 07xx) does not seem to have any helpful application in the context of a faulty line - be that a short or long term issue. Note this a very different service to a complete bar on outbound calls - is that what you were thinking of?
2. Will you please pass onto your product packaging team / marketing that there is consumer demand for the "standard" services technically available on the BT phone network, but not presently commercially available via PlusNet, asking that these limitations be reviewed at the next product refresh. Such limitations are frustrating to users and are potentially a negative selling point.
Thanks,
Kevin
