Password to broadband service (Fibre)
bluegunk
Help! Setting up new router, I can't remember my login password to broadband!
How can I discover what it is or reset it please?
2 REPLIES 2
Legend
Fixes: 255
Re: Password to broadband service (Fibre)
It is the one you use to open your account. Did you not take a note of this important information?
bluegunk
Thanks, John. Yes I have very detailed info on my password set up. But of course, this was the one thing I didn't note - it being the same!  But I discovered that as you posted your fix.
Thank for your time and help!
Clive
