Password to broadband service (Fibre)
FIXEDTopic Options
- Password to broadband service (Fibre)
11-02-2023 12:08 PM
Help! Setting up new router, I can't remember my login password to broadband!
How can I discover what it is or reset it please?
Fixed! Go to the fix.
Message 1 of 3
(644 Views)
2 REPLIES 2
11-02-2023 12:15 PM
It is the one you use to open your account. Did you not take a note of this important information?
Message 2 of 3
(638 Views)
Re: Password to broadband service (Fibre)
11-02-2023 12:36 PM
Thanks, John. Yes I have very detailed info on my password set up. But of course, this was the one thing I didn't note - it being the same! But I discovered that as you posted your fix.
Thank for your time and help!
Clive
Message 3 of 3
(623 Views)
