Password for thomson 585 v7 router
flipster
Hello!
I am probably asking a really stupid question so I'm sorry!
When I first signed up with plusnet over a year ago I paired my laptop to my router so that I wouldnt have to keep inputting the passcode, I'd like to use wifi with my iphone at home but I can't work out which one of the stickers (if any) is the password as I didnt change it when I set up my wifi... so in short the question is how do I find out the password, as Ive lost the booklet and instructions that the router came with!!
Any help would be very much appreciated!!
Em
Fixes: 55
Re: Password for thomson 585 v7 router
If it's the Wi-Fi password you are looking for it should be the one that appears alongside WPA-PSK on the Wi-Fi certified label underneath.
Otherwise you'd have to login to the router and go to the Home Network WLAN page.
David
flipster
Thank you so much!! thats great!!
Thanks again!
