Password and user name
- Password and user name
04-11-2014 11:15 AM
This seems to happen when I shift to another web site.
Truth is like a threshing machine; tender sensibilities must keep out of the way.
Herman Melville
Re: Password and user name
04-11-2014 11:30 AM
Welcome to the forums.
Can I clarify your question. Are you referring to a login in screen being displayed by the router? Does it look similar to this - http://192.168.1.254 ?
If yes it rather suggests a connectivity or DNS issue.
If you click BACK on your browser and the link you want does it then work?
Next time it happens, can you please login to your router (see above link) and look at the router log to see if it reports a connectivity issue.
04-11-2014 12:31 PM
I will do as you suggest next time it happens. Cheers.
Herman Melville
04-11-2014 12:40 PM
I have a theory (could be irrelevant!) - can you please advise if your WAN address starts with 146.199 - look at the internet connection details in the router.
04-11-2014 1:32 PM
05-11-2014 3:15 AM
