turn on suggestions
Panasonic DMR-PWT635 Won't Connect to internet
- Panasonic DMR-PWT635 Won't Connect to internet
14-03-2015 9:10 PM
I am not particularly clued up on IP's, DNS's and Gateways, and usually rely on auto setup functions. However, I have today bought a Panasonic DMR-PWT635 and the easy setup to connect it to my WiFI has not worked (even after several attempts).
I have a Standard PlusNet Router (having only joined 2 months ago).
On the device I go to Easy Network Setting (Home Network Connection Check) and I get the following Results:
1. Wiresless Setting - Pass
2. IP Address Setting - Home Network Available
3. Connection to Gateway - Fail
Looking in the trouble shooting section of the manual it says Check "settings IP Address, DNS settings".
I have know idea what this means, what I should be checking or what to change.
Any help to get this device connected would be much appreciated.
Re: Panasonic DMR-PWT635 Won't Connect to internet
14-03-2015 9:12 PM
Try setting the IP etc manually
IP address 192.168.1.200
Subnet 255.255.255.0
Gateway 192.168.1.254
DNS server 8.8.8.8
See if that helps
DNS server 8.8.8.8
See if that helps
14-03-2015 9:14 PM
More discussion on similar issues here
http://community.plus.net/forum/index.php/topic,122172.0.html
19-03-2015 7:12 PM
Thanks Managed to connect manually using the codes on the related thread.
Just need my broadband speed to be increased as everything keeps freezing!
Thanks for you help.
21-03-2015 7:44 AM
Welcome to the forums.
First I would suspect wifi congestion. Streaming over wifi is not ideal, are you able to get a wired connection for the TV?
Also take a look at the speed issues thread and post the requested data under a new thread with a relevant title please.
@mods,
Merge this thread with the referred too TV problem thread ... Or lock it?
@CRT,
Given that this is a reoccurring theme, can products raise the issue with TG to find out what is going wrong with the DHCP offer process here? It sounds not unlike the issues I have reported with Vista platforms.
@mods,
@CRT,
