Painfully Slow Web Browsing
- Painfully Slow Web Browsing
20-12-2008 2:21 PM
My sync sped is normal and I've just run a speed test which is also fine. I've also tried rebooting my router and de-installing the recent IE security patch (KB960714) as my problems seemed to start after I had installed this. Neither of these things have made any difference.
If I connect my works laptop wirelessly then everything is fine (using a VPN). My normal PC (the one on which I'm having problems) is wired to the router.
Now I'm stumped - any ideas please?
Bob
Re: Painfully Slow Web Browsing
20-12-2008 2:26 PM
www.paypal.co.uk
www.bbc.co.uk
www.microsoft.com
Bob
20-12-2008 2:47 PM
Last night's problems with Plusnet websites were due to a caching DNS misbehaving, fixed round about midnight. Your assumption that a repeat of this problem would have been noticed by other users is a fair one to make.
David
20-12-2008 3:09 PM
I'm a but nervous of changing MTU - I've never touched this setting in years and not had any problems before. My router is saying that MTU is set to 1458 by the way.
My exchange is green (it took 5 minutes for me to get on to the exchange checker site).
I've just tried pinging www.bbc.co.uk and am getting request timed out.
A tracert gives:
C:\Documents and Settings\Owner>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.253.67]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms www.routerlogin.com [***.***.0.1]
2 20 ms 16 ms 18 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 15 ms 16 ms 17 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 19 ms 20 ms 16 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 154 ms 55 ms 17 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 16 ms 15 ms 15 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 16 ms 16 ms 16 ms 212.58.238.133
8 16 ms 17 ms 17 ms te12-1.hsw0.cwwtf.bbc.co.uk [212.58.239.222]
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 ^C
A tracert to www.plus.net gives:
C:\Documents and Settings\Owner>tracert www.plus.net
Tracing route to portal.plus.net [212.159.8.2]
2 19 ms 28 ms 18 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 17 ms 17 ms 16 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 16 ms 18 ms 17 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 24 ms 16 ms 18 ms te2-4.pte-gw2.plus.net [212.159.1.102]
6 20 ms 16 ms 22 ms ae0-102.ptn-gw02.plus.net [212.159.1.105]
7 19 ms 20 ms 21 ms gi0-1-31.ptc-gw1.plus.net [195.166.129.3]
8 26 ms 23 ms 26 ms pos1-0.pih-cr1.plus.net [195.166.129.250]
9 26 ms 26 ms 28 ms vlan8.pih-gw4.plus.net [212.159.0.30]
10 26 ms 28 ms 25 ms if25.pih-lb04.plus.net [212.159.0.18]
11 27 ms 26 ms 68 ms portal.plus.net [212.159.8.2]
Trace complete.
Does any of this help?
Bob
20-12-2008 3:42 PM
otherwise i might try rebooting my router (assuming that's what you're using too)
20-12-2008 4:03 PM
Thanks both for your help but I've had enough for today - this has already taken up way too much of my time. In good optimistic fashion, I'll switch off and hope it's all ok by tomorrow !!!
Bob
21-12-2008 1:17 AM
Before changing anything I suggest running a tweak test at DSLreports. To get the results set Service to dsl, enter 8000 for Download Speed, set Operating System to winXP (in your case), and leave Connection as normal. Please post the results URL you will find in small letters just above the red Do Not Copy/Paste the Page text.
Also download DrTCP from the site. I suggest picking the ".exe" version, it's only 52.5KB. Double-click the downloaded file to run it, it's a self-contained executable that doesn't install on your computer. If you ensure the Adapter Settings drop-down shows the correct adapter (you might only have one) the MTU value will be shown in the right-hand box (blank means 1500).
David
21-12-2008 7:49 AM
David, I've run the tweak test and the url is http://www.dslreports.com/tweakr/block:afde99?service=dsl&speed=8000&os=winXP&via=normal
I've run DrTCP and attached a screenshot of the result. I'm getting a bit out of my depth here and I'm not sure what my adapter settings are. I left it as the default which was Ethernet Adapter. I am using Ethernet to my router.
Thanks again for your help.
Bob
21-12-2008 12:04 PM
I've had a read around about MTU and RWIN and have changed my router MTU to 1500 and my RWIN to 130456. The tweak test is now giving http://www.dslreports.com/tweakr/block:2fc92a0?service=dsl&speed=8000&os=winXP&via=normal so I appear to have optimised these settings. I ran a before and after speedtest with no discernable difference but hopefully I've not made it any worse.
Thanks to David for you help on this.
Bob
21-12-2008 12:19 PM
Well done, you've made the changes I was about to suggest (I was going to suggest RWIN=128480 which is the value I use, but anything around that value is fine).
The data transfer on the original setting is a little smoother, but idle time has been reduced slightly with the latter. Sort of swings and roundabouts. I suggest seeing how things go with these settings. It's likely that outgoing packets could have been fragmented with the previous setting which might have caused the problems you experienced - time will tell.
If you do a speedtest now is the download speed a little faster?
David
22-12-2008 7:07 AM
Quote from: spraxyt If you do a speedtest now is the download speed a little faster?
Speedtest results are about the same as before.
Bob
22-12-2008 12:34 PM
David
