Packet loss...
- Packet loss...
Re: Packet loss...
04-05-2009 8:58 PM
Re: Packet loss...
05-05-2009 8:08 AM
Re: Packet loss...
08-05-2009 2:02 PM
Re: Packet loss...
08-05-2009 4:33 PM
Hopefully one of the network guys will take a look at your updated ticket soon. Sorry for the delay!
Ex-Broadband Service Manager
Re: Packet loss...
08-05-2009 6:21 PM
According to the wireshark capture I just did, packets are being given the correct platinum status when they are travelling from the server to my pc, but bronze when they are travelling the other way...
thanks for the reply
Re: Packet loss...
08-05-2009 7:13 PM
asbo. runs and hides from the jaws gang
Re: Packet loss...
08-05-2009 7:39 PM
Re: Packet loss...
12-05-2009 12:52 PM
Only progress my ticket seems to have made is that the network people have worked out that my traffic is being prioritized correctly...
Is there anything else I can try??? I'm desperate!!
Re: Packet loss...
12-05-2009 6:19 PM
SF:
SF Errors:
Reed Solomon:
RS Corrected:
RS Un-Corrected:
HEC:
Errored Seconds:
Severe ES:
CRC:
LOS:
LOF:
did you have interleaving turned off ?
Re: Packet loss...
12-05-2009 7:53 PM
BusyBox v1.00 (2008.11.17-03:13+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# cat /tmp/adsl-stats
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 4352 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 14.3 19.0
Attn(dB): 40.0 22.0
Pwr(dBm): 19.8 11.8
Max(Kbps): 4608 980
Rate (Kbps): 4352 448
G.dmt framing
K: 137(0) 15
R: 0 0
S: 1 1
😧 1 1
ADSL2 framing
MSGc: 1 1
B: 137 15
M: 1 1
T: 1 1
R: 0 0
S: 1.0000 1.0000
L: 1104 128
😧 1 1
Counters
SF: 1619903 1619908
SFErr: 875 0
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 258 0
OCD: 0 0
LCD: 0 0
Total Cells: 282657868 0
Data Cells: 19592665 0
Drop Cells: 0
Bit Errors: 0 0
ES: 860 0
SES: 0 0
UAS: 14 0
AS: 27540
INP: 0.00 0.00
PER: 1.75 1.75
delay: 0.25 0.25
OR: 32.00 32.00
Bitswap: 0 0
Total time = 7 hours 39 min 24 sec
SF = 1619903
CRC = 875
LOS = 0
LOF = 0
ES = 860
Latest 1 day time = 7 hours 39 min 24 sec
SF = 1619903
CRC = 875
LOS = 0
LOF = 0
ES = 860
Latest 15 minutes time = 9 min 24 sec
SF = 33158
CRC = 29
LOS = 0
LOF = 0
ES = 27
Previous 15 minutes time = 15 min 0 sec
SF = 52923
CRC = 35
LOS = 0
LOF = 0
ES = 35
Previous 1 day time = 0 sec
SF = 0
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52982
CRC = 35
LOS = 0
LOF = 0
ES = 35
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52923
CRC = 48
LOS = 0
LOF = 0
ES = 48
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 34
LOS = 0
LOF = 0
ES = 34
Showtime Drop Reason: 0
Last Retrain Reason: 0
Hope that helps. I did request interleaving be turned off in a ticket in the hope it might help my problem but don't think it has happened yet, pings still as high as they used to be.
Cheers
Re: Packet loss...
12-05-2009 8:21 PM
heres my fastpath errors on adsl2 and they dont cause any problems with XBL
Noise Margin: 7.3 dB
Connection Rate: 4544 Kbps
Line Attenuation: 50.5 dB
Power: 0.0 dBm
Max Rate: 5568 Kbps
Total Up Times (From SF counts):
WAN: 1 day, 21:20:17
LAN: 1 day, 22:48:41
CRC: 1800
LOS: 0
LOF: 0
SF: 9596086
SF Errors: 1791
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 1274
Errored Seconds: 827
Severe ES: 16
Interleave Depth: 1
CRC: 1800
LOS: 0
LOF: 0
C:\Users\>ping bbc.co.uk
Pinging bbc.co.uk [212.58.254.252] with 32 bytes of data:
Reply from 212.58.254.252: bytes=32 time=16ms TTL=249
Reply from 212.58.254.252: bytes=32 time=15ms TTL=249
Ping statistics for 212.58.254.252:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 15ms, Maximum = 16ms, Average = 15ms
can you run a tracert from the pc you game with please ?
Quote This is all the stats I can get from my router (netgear DG834):
have you ruled the router out by testing another? and made sure all ports et are forwarded and setup right for your games
Re: Packet loss...
12-05-2009 8:49 PM
Re: Packet loss...
12-05-2009 8:51 PM
Quote from: ASBO have you ruled the router out by testing another? and made sure all ports et are forwarded and setup right for your games
Yes, different router didn't make a difference. I had a Belkin originally and bought this when the problem emerged...
Yeah, all ports forwarded correctly even though they were never set up before the problems started and it didn't stop it working!
Thanks for the help btw
Re: Packet loss...
12-05-2009 10:12 PM
Have you considered having interleaving turned on?
Re: Packet loss...
12-05-2009 10:39 PM
