Packet loss...
- Packet loss...
Packet loss...
01-05-2009 9:26 AM
I'm thinking its packet loss, and have run a line quality test on dslreports.com (see link to my results below)
Any ideas what has happened here?
Bt speed tester Results:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 5824 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 5000 kbps
Actual IP throughput achieved during the test was - 4254 kbps
Results of dslreports.com packetloss test: http://www.dslreports.com/linequality/nil/2516188
My forum post on low speed prob: http://community.plus.net/forum/index.php/topic,73950.0.html
Re: Packet loss...
02-05-2009 11:44 AM
The connection rate from the above BT speed test is below what your line should be capable of based on the information in your low speed problem thread, and this is why you won't be getting the throughput speeds of around 6M that your friend gets. Can you post the current Router ADSL Line stats (sync/connection rate, attenuation and Noise Margin). We won't be interested in any more BT speedtest results fro a while.
Did you carry out what I suggested in reply #51 & #52 in your low spead thread? you didn't respond - perhaps you could advise the outcome.
Re: Packet loss...
02-05-2009 1:07 PM
ADSL Link Downstream Upstream
Connection Speed 5728 kbps 448 kbps
Line Attenuation 40.0 db 22.0 db
Noise Margin 11.1 db 21.0 db
thanks
Re: Packet loss...
02-05-2009 2:50 PM
Re: Packet loss...
02-05-2009 3:04 PM
Pinging www.bbc.net.uk [212.58.253.67] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 212.58.253.67:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Documents and Settings\Bobby>tracert www.bbc.co.uk
Tracing route to www.bbc.net.uk [212.58.253.67]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 33 ms 31 ms 31 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 33 ms 31 ms 32 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 32 ms 31 ms 30 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 32 ms 32 ms 32 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 31 ms 33 ms 31 ms 212.58.238.149
7 32 ms 31 ms 32 ms te12-1.hsw1.cwwtf.bbc.co.uk [212.58.239.234]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * ... etc
Re: Packet loss...
02-05-2009 4:20 PM
C:\Users\*******>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.254.252]
1 1 ms 1 ms 1 ms 10.0.0.1
2 16 ms 15 ms 16 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 16 ms 15 ms 28 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 16 ms 15 ms 17 ms rt0.thdo.bbc.co.uk [212.58.239.25]
5 16 ms 16 ms 17 ms 212.58.238.133
6 16 ms 15 ms 15 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
7 16 ms 16 ms 16 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
EDIT: i see if you use www it converts the address to .net.uk
Re: Packet loss...
02-05-2009 4:28 PM
Re: Packet loss...
02-05-2009 4:35 PM
Quote from: ASBO why is the op's converting bbc.co.uk to bbc.net.uk on there tracert's
In DNS ww.bbc.co.uk is a CNAME record pointing to www.bbc.net.uk :-
mike@lucy ~ $ nslookup www.bbc.co.uk
Server: ::1
Address: ::1#53
Non-authoritative answer:
www.bbc.co.uk ; canonical name = www.bbc.net.uk.
Address: 212.58.253.68
Mike
Re: Packet loss...
03-05-2009 7:34 AM
Pinging bbc.co.uk [212.58.254.252] with 32 bytes of data:
Reply from 212.58.254.252: bytes=32 time=33ms TTL=248
Reply from 212.58.254.252: bytes=32 time=31ms TTL=248
Reply from 212.58.254.252: bytes=32 time=29ms TTL=248
Reply from 212.58.254.252: bytes=32 time=30ms TTL=248
Ping statistics for 212.58.254.252:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 29ms, Maximum = 33ms, Average = 30ms
C:\Documents and Settings\Bobby>tracert bbc.co.uk
2 31 ms 31 ms 31 ms lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
3 30 ms 30 ms 30 ms ge0-0-0-403.pte-gw2.plus.net [84.92.4.2]
4 32 ms 32 ms 31 ms vl23.thn-gw2.plus.net [212.159.4.20]
5 29 ms 32 ms 31 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 31 ms 31 ms 31 ms 212.58.238.133
7 31 ms 31 ms 31 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
8 31 ms 31 ms 31 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
Re: Packet loss...
03-05-2009 4:14 PM
ping -t bbc.co.uk
and to stop it
crtl + c
it keeps the ping going so you will get a better idea of packet loss
Re: Packet loss...
03-05-2009 5:40 PM
I'm guessing your issues are more related to some of the network problems that have been affecting a number of users.
As a Gamer, you'll probably be better off having interleaving turned off. If you can't find a setting for this at the member centre to get it turned off, you'll need to raise a ticket.
If your pings seem OK, it may then be best to start a thread on the specific game issue on the Gamers Forum board. ASBO and a few others over there I'm sure will be able to help. In the meantime, post some more pings.
Re: Packet loss...
03-05-2009 7:17 PM
just done the same test on dslreports and got same results check this link yours and mine are there. mine is on the 3rd page under scootie.
http://www.dslreports.com/linequality/nil?dnsdom=plus.net
Re: Packet loss...
04-05-2009 12:42 PM
Quote from: Anotherone I'm guessing your issues are more related to some of the network problems that have been affecting a number of users.
I'm starting to think so, as using ping -t bbc.co.uk worked succesfully with not packet loss for about 10 minutes. Have raised a ticket and received a reply telling me that packet loss issues may be related to a problem with the network. Hopefully it'll be sorted soon.
Thanks for the advice, i'll raise a ticket to get interleaving turned off too.
Have included a screenshot from in game to give you an idea of the packet loss
Re: Packet loss...
04-05-2009 5:08 PM
try running a ping to somthing in the same country to see if you get any packet loss then
Re: Packet loss...
04-05-2009 7:54 PM
and pinging the same servers out of game through command prompt doesn't give any packet loss......
