Packet Loss
simonhiggs
Packet Loss
I wonder what's causing packet loss on my BQM? Doesn't seem to relate any way to errors reported by my Fritz!Box.
Simon.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Packet Loss
Hi simonhiggs,
I've tested your line to see if there's anything I can see. We've detected a potential problem with your telephone service. Can you please pick up your handset and dial 17070 and carry out the 'Quiet Line Test' and let us know if you can hear any noise on the line?
Chris Pettitt
Cloud Environments Engineer
simonhiggs
Re: Packet Loss
Hello Chris,
I've plugged a corded phone in (normally the Fritz!box is connected to the two sockets) and there's no noise.
Simon.
Re: Packet Loss
Are you able to try a disconnect/reconnect on your line? You'd be best to login to your router to do this.
simonhiggs
Re: Packet Loss
OK, done
24.06.14 11:40:11 IPv6 prefix obtained successfully. New prefix: 2a02:16c8:889f:a800::/56
24.06.14 11:40:11 IPv6 Internet connection established successfully. IP address: 2a02:16c8:889f:a800:c225:6ff:fe0d:9b18
24.06.14 11:40:05 Internet connection established successfully. IP address: 212.159.122.149, DNS server: 212.159.6.9 and 212.159.6.10, Gateway: 195.166.130.151, Broadband PoP: bras-red12.l-far-B226E1811E038P
24.06.14 11:39:51 Internet connection cleared.
Simon.
simonhiggs
Re: Packet Loss
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Packet Loss
Does this appear to be happening on a daily basis?
Chris Pettitt
simonhiggs
Re: Packet Loss
30 days since May 22nd. About 75%
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Packet Loss
I would suggest raising a fault and providing a link to your TBB Graph. You can do this at http://faults.plus.net
Chris Pettitt
xreyuk
Re: Packet Loss
I have two ping monitors running, one from TBB and the other from F8lure (F8lure also runs a second ping using AAISP, who use the same equipment as TBB).
My TBB always shows more packet loss, it can even show packet loss when the other graph shows none. Personally, I ignore packet loss unless it shows on both graphs.
simonhiggs
Re: Packet Loss
I was ignoring it until I had a couple of VOIP calls dropped and streaming R4 Play for Today was interrupted!
I've set up a F8lure test to compare - thanks Xreyuk.
http://higgs.me.uk/bqm/bqm.html
Simon.
simonhiggs
Re: Packet Loss
Quote from: Chris
Hi simonhiggs,
Hello Chris,
Just out of curiosity (as there's no noise on a Quiet Line Test) what was the 'potential problem' that you detected?
Best regards. Simon.
Acassim
Re: Packet Loss
Hi Simon,
Unfortunately Chris has moved on to pastures new within the business so I'm afraid this may be tough to check.
I'm happy to re-run the test for you and see if the same issue is flagged however this may not return the same results given the length of time since the detection.
simonhiggs
Re: Packet Loss
Hello Adam,
I realise it's been a couple of months since Chris tested the line. I have an ongoing case with AVM support regarding the packet loss reported by the ThinkBroadband BQM tool.
My Broadband Ping
They think that my Fritz!Box router is not the cause, but are still looking into the issue.
I am seeing an increased number of reconnections. The router shows 6 last month and 5 this month (Previously my Be LLU ADSL would stay connected for months at a time, on a 3db profile). Also interleaving has just been applied to the line. My current line speed has dropped very slightly to 76.8Mb, but this is about 20Mb down on my attainable data rate when I joined Plus Net, 9 months ago.
I would be pleased if you could run the test again.
Best regards, Simon.
JTaylor
Re: Packet Loss
Hi Simon
Thanks for bearing with us over the bank holiday  Smiley
I have re-ran the tests and we are no longer seeing any potential issues with your service.
Are you still experiencing the packet loss you noted previously?
