Packet Loss / High latency in evenings
RealAleMadrid
Fixes: 66
Re: Packet Loss / High latency in evenings
@smyth1492  The HUB2 can be set to bridge mode and used as a modem and connected to a router or mesh system that can provide a PPPoE wan connection. Your user credentials would be entered in the router.
I don't use ISP supplied routers so can't help you with the HUB2 setup but there should be info in the router forum board.
Fixes: 122
@smyth1492
To change the Hub two to bridge mode (as a modem)
http://192.168.1.254 Advanced Setting > Broadband >Internet > Bridging >Enabled. Save settings
The Hub will reboot and the led will go pink.
Use any LAN port to connect to WAN of router.
HTH
smyth1492
It looks like my Orbi supports the PPPoE so I should be able to make this change. I just need to come up with a plan for the devices that have a ethernet connection as I don't currently have enough ports available. I might try the change without sorting the ethernet ports out to see if this solves the performance issue or not.
