Package Change?
- Re: Package Change?
Package Change?
05-04-2010 2:26 PM
Would it be possible to be moved from the Pro package to the Premier package? Although the Pro package is just what we wanted speed wise the 20GB isn't enough and I have a feeling we're not going to make it anywhere near the end of the month without being limited. I thought I'd ask here because as I understand it if I submit a ticket the change is carried out on the next billing date, which would most likely result in at least a week of being throttled :(.
If interleaving is switched on when the package switches would it be possible to have it switched off again as I would certainly miss my 20ms ping!
If anyone has moved from Pro to Premier, would they be able to tell me if the change is noticeable, especially with gaming?
Thanks,
GeneGenie
Re: Package Change?
07-04-2010 10:04 AM
Any account change has to be done on the billing date I'm afraid but moving to Premium from Pro won't be a problem. We can certainly remove interleaving if it is turned on but I'd be very surprised if this happened following an account change.
As for the final question, I'll leave that to someone else to answer - better from a customer than a staff member I suspect
Re: Package Change?
07-04-2010 10:40 AM
If Plusnet haven't got signatures for the games you use you should see a distinct improvement on those games.
Re: Package Change?
07-04-2010 11:51 AM
Just wanted to say how pleased I am with Plusnet so far...better in every way than my old Sky package so thank you very much! :).
@jelv An improvement on games Plusnet haven't got signatures for? I would of thought it would be slightly worse after the 'downgrade'.
Also, from looking at the broadband download speeds for Premium, YouTube is limited at 2.5Mb in the evenings, as I'm only connecting at 3.5Mb will I actually notice any difference?
Thanks for all your help,
GeneGenie
Re: Package Change?
07-04-2010 11:53 AM
Re: Package Change?
07-04-2010 11:54 AM
Re: Package Change?
07-04-2010 12:14 PM
Quote from: GeneGenie @jelv An improvement on games Plusnet haven't got signatures for? I would of thought it would be slightly worse after the 'downgrade'.
Memo to self - read the OP properly - I read it the other way round (Premier -> Pro). I think you've interpreted my reply correctly.
Re: Package Change?
07-04-2010 12:39 PM
Re: Package Change?
07-04-2010 1:27 PM
From last package changes those on BBYW could and I think still can move between the different BBYW ones, but not sure about this next change
Re: Package Change?
07-04-2010 1:40 PM
Re: Package Change?
07-04-2010 2:13 PM
Our interpretation of what has been posted is that it will be equivalent to Premium otherwise but that remains to be confirmed. To maximise options why not upgrade to Premium now (taking effect from next billing date), then change to Extra later when full details of the package are available?
Re: Package Change?
07-04-2010 4:29 PM
