Package Change
- Re: Package Change
Package Change
25-11-2007 10:33 PM
I'm on Broadband Premier Option 1 (£21.99 month)
I get an "unlimited" off peak allowance, with a peak allowance of 12gig (i think). Peak time is 4pm till midnight.
I am thinking of moving to the PRO package (£19.99) with 20gig allowance.
Is the 20 gig a total limit? Or is it a peak time limit as i have now?
I've used about 30gig each month, with peak time usage being around 9gig - 16gig.
What would you recommend?
Re: Package Change
25-11-2007 10:34 PM
Re: Package Change
25-11-2007 10:48 PM
For your usage it might be worth considering BBYW option 4 which would be £24,99 a month for 6 months (£29,99 thereafter) and gives a whopping 40GB allowance - all packages give free usage from midnight to 8am daily
I'm not 100% sure on the limits on BPO1 - although the 12,13gb mark does sound familiar.
To be honest if you get unlimited off peak it might be worth you staying there, unless you can/are happy to schedule downloads for overnight
Re: Package Change
26-11-2007 9:08 AM
Quote from: pcoventry For your usage it might be worth considering BBYW option 4 which would be £24,99 a month for 6 months (£29,99 thereafter) and gives a whopping 40GB allowance
Pete,
the OP has stated that they use 9 - 16 GB peak time, so I would have thought that BBYW option 3 would be more suitable, not to mention a more appropriate price range.
Manguish,
the peak time periods on the BBYW products, are 0800 - midnight, unlike the Prem you have now, which is 1600 - midnight.
Your prem package has a peak time allowance of 20 Gb, but is shaped (slowdown) after 13 Gb, whereas the BBYW peak time allowance for option 3, is 20 Gb with no extra shaping (slowdown) within the allowance.
Re: Package Change
26-11-2007 9:15 AM
Your current Broadband Premier product offers up to 20GB peak time usage (4pm to midnight) with no set limits on off peak. Peak time restriction come into force from 13GB.
The Broadband Your Way Pro product offers 10GB during peak times (8am to midnight) where all traffic will come down at the fastest rate our network will allow (this is line rate under normal network conditions).
For the nearest non Pro equivalent, you would be looking at Option 3, which offers 20GB peak time usage (8am to midnight) for £19.99.
Let me know if you need any help.
Re: Package Change
27-11-2007 12:10 AM
I don't mind paying for 20gig's worth of peak, on Pro. But that 20gig has to be used over a much longer time (8 hours).
Is that right?
I like the idea of fastest rates at all times, but i don't like the increase of peak time hours.
Hmm. What a dilemma.
Re: Package Change
27-11-2007 1:09 AM
It's been done before for people anyhow.
Re: Package Change
27-11-2007 10:23 AM
Re: Package Change
27-11-2007 9:36 PM
Do i just PM you once i'm ready to try it then?
Re: Package Change
27-11-2007 10:51 PM
Quote from: Manguish So in reality, i'm better off staying where i am for now, as the peak time is less (4pm till midnight) instead of 8am till midnight.
Is that right?
What you have to remember switching to any BBYW you lose 8 hours off peak per day.
Some say I am at work all day so it does not matter. But it will affect you at weekends.
You lose of 16 hours off peak every weekend. Then add up the hours you lose if you have a week off work
Puddy
