PTN-AG2 packet drops
Fixes: 21
I notice from the data that there was a drop of 46.6331% packets just after 10pm on the 27th.
Does anyone know what the cause of this enormous amount was?
Fixes: 62
Re: PTN-AG2 packet drops
possibly something to do with this http://usertools.plus.net/status/archive/1230386104.htm
Fixes: 21
That was a lot earliuer in the day!
Fixes: 62
Yes but it might have done a good job in unbalancing the pipes
Fixes: 21
That was the only gateway showing any drops at or near that time, and I don't recall seeing drops of that magnitude ever before (they may have occurred and I'd not noticed!). Come on some one from PN, any info.?
Fixes: 21
Is anyone from PN going to take ownership of this one please?
James
Hi Chris,
I don't have any specific information I'm afraid, but if it was on the same day as a pipe drop, there's a possibility that that pipe became more quickly loaded than the others causing a higher level of packet loss.  It could also be a blip in the reporting software.
Fixes: 21
Has anyone looked at this?
Quote from: Anotherone
That was the only gateway showing any drops at or near that time, and I don't recall seeing drops of that magnitude ever before (they may have occurred and I'd not noticed!).......
And there were no other drops on that gateway earlier in the day.
I would have thought drops of 46+% warranted some quick checks!
James
In honesty, given it was a couple of weeks ago, I doubt we're going to get an answer on that one.
I know it's not the answer that you're looking for, but given that it's something that happened in the past and is no longer an issue, I can't see it causing any problems.
Fixes: 21
[sarcasm mode]
Depends what the cause was! It might or not have helped point the finger in the direction of something that is misbehaving from time to time but not obvious, which is causing other random or intermittent issues. But there again it might not have and be totally unrelated to anything. Obviously no engineers around at the moment.
[/sarcasm mode]
Fixes: 81
I'd take a look at the reporting graphs but they don't go back that far I'm afraid. I'd have to agree with James on this one - we've not got much to go on so I don't think there's really a realistic way to find out what caused the packet drops.
Fixes: 21
Never mind then Bob, thanks for your comment.
