PPoE Based Disconnections?
Nessworthy
Hello!
I've been racking my brain on this issue pretty much since I can remember, ended up replacing our network setup twice to try and alleviate the disconnects to no avail. Uncommonly, usually in the late hours, the internet connection will completely drop for a few minutes usually. Sometimes longer. The frequency at which it comes up and down is pretty random, but it usually happens 2-5 times in a row.
The UniFi security gateway I have flags them as "WPA Authentication Timeout/Failure", and the logs are posted below.
Would anyone be able to help me understand what's going on?
Oct 1 21:08:01 MainRouter ntpd[11742]: ntpd exiting on signal 15
Oct 1 21:08:03 MainRouter pppd[9202]: Connection terminated: no multilink.
Oct 1 21:08:03 MainRouter zebra[679]: interface pppoe0 index 74 deleted.
Oct 1 21:08:03 MainRouter pppd[9202]: Modem hangup
Oct 1 21:08:04 MainRouter ntpd[11989]: ntpd 4.2.6p2@1.2194-o Wed Sep 27 04:27:31 UTC 2017 (1)
Oct 1 21:08:04 MainRouter ntpd[11990]: proto: precision = 50.551 usec
Oct 1 21:08:06 MainRouter ntpd_intres[11995]: host name not found: 0.ubnt.pool.ntp.org
Oct 1 21:08:06 MainRouter ntpd_intres[11995]: host name not found: 1.ubnt.pool.ntp.org
Oct 1 21:08:06 MainRouter ntpd_intres[11995]: host name not found: 2.ubnt.pool.ntp.org
Oct 1 21:08:06 MainRouter ntpd_intres[11995]: host name not found: 3.ubnt.pool.ntp.org
Oct 1 21:09:08 MainRouter ntpd_intres[11995]: host name not found: 0.ubnt.pool.ntp.org
Oct 1 21:09:08 MainRouter ntpd_intres[11995]: host name not found: 1.ubnt.pool.ntp.org
Oct 1 21:09:08 MainRouter ntpd_intres[11995]: host name not found: 2.ubnt.pool.ntp.org
Oct 1 21:09:08 MainRouter ntpd_intres[11995]: host name not found: 3.ubnt.pool.ntp.org
Oct 1 21:09:08 MainRouter pppd[9202]: Timeout waiting for PADO packets
Oct 1 21:09:23 MainRouter pppd[9202]: Connected to 20:e0:9c:c1:fe:50 via interface eth0
Oct 1 21:09:23 MainRouter zebra[679]: interface ppp0 index 75 <POINTOPOINT,NOARP,MULTICAST> added.
Oct 1 21:09:23 MainRouter pppd[9202]: Connect: ppp0 <--> eth0
Oct 1 21:09:23 MainRouter zebra[679]: interface ppp0 mtu changed from 1500 to 1492
Oct 1 21:09:23 MainRouter zebra[679]: interface ppp0 mtu changed from 1492 to 1500
Oct 1 21:09:23 MainRouter pppd[9202]: CHAP authentication succeeded
Oct 1 21:09:23 MainRouter pppd[9202]: peer from calling number 20:E0:9C:C1:FE:50 authorized
Oct 1 21:09:23 MainRouter zebra[679]: warning: PtP interface ppp0 with addr 80.229.223.104/32 needs a peer address
Oct 1 21:09:23 MainRouter zebra[679]: interface index 75 was renamed from ppp0 to pppoe0
Oct 1 21:09:23 MainRouter zebra[679]: interface pppoe0 mtu changed from 1500 to 1492
Oct 1 21:09:24 MainRouter pppd[9202]: local IP address [MY PUBLIC IP]
Oct 1 21:09:24 MainRouter pppd[9202]: remote IP address 195.166.130.252
Oct 1 21:09:24 MainRouter zebra[679]: interface pppoe0 index 75 changed <UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>.
Oct 1 21:09:24 MainRouter pppd[9202]: primary DNS address 212.159.6.9
Oct 1 21:09:24 MainRouter pppd[9202]: secondary DNS address 212.159.6.10
pppoe logs specifically have the following:
No response to 6 echo-requests
Serial link appears to be disconnected.
ipcp: down
Connect time 4.3 minutes.
Sent 72341 bytes, received 129401 bytes.
Script /etc/ppp/ip-down started (pid 13286)
sent [LCP TermReq id=0x3a "Peer not responding"]
sent [LCP TermReq id=0x3b "Peer not responding"]
Modem hangup
Script /etc/ppp/ip-down finished (pid 13286), status = 0x0
using channel 71
Using interface ppp0
sent [LCP ConfReq id=0x3c <mru 1492> <magic 0xf3f2e714>]
rcvd [LCP ConfReq id=0x84 <mru 1492> <auth chap MD5> <magic 0x18ea3a43>]
lcp_reqci: returning CONFACK.
sent [LCP ConfAck id=0x84 <mru 1492> <auth chap MD5> <magic 0x18ea3a43>]
rcvd [LCP ConfAck id=0x3c <mru 1492> <magic 0xf3f2e714>]
IPCP: Up event in state 2!
rcvd [CHAP Challenge id=0x1 <bc414ef48566d38a7e6e7c3f433b360b5236c127416cddd9732571c6cf66a78ca87501>, name = "acc-aln3.ngf"]
sent [CHAP Response id=0x1 <61e786a8aedc672ebf47795db886e219>, name = "MYUSER@plusdsl.net"]
rcvd [LCP ConfReq id=0x0 <auth chap MD5> <magic 0x26b78236>]
sent [LCP ConfReq id=0x3d <mru 1492> <magic 0x636f02>]
sent [LCP ConfAck id=0x0 <auth chap MD5> <magic 0x26b78236>]
rcvd [LCP ConfAck id=0x3d <mru 1492> <magic 0x636f02>]
sent [LCP EchoReq id=0x0 magic=0x636f02]
rcvd [CHAP Challenge id=0xa3 <03c94522e83986712df291915159f40d3c5ab7>, name = "JUNOS"]
sent [CHAP Response id=0xa3 <6a68a54a066a1cd83ca7f1b55b7c9583>, name = "MYUSER@plusdsl.net"]
rcvd [LCP EchoRep id=0x0 magic=0x26b78236]
rcvd [CHAP Success id=0xa3 ""]
sent [IPCP ConfReq id=0x1f <addr 0.0.0.0> <ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
rcvd [IPCP ConfNak id=0x1f <addr [MY PUBLIC IP]> <ms-dns1 212.159.6.10> <ms-dns3 212.159.6.9>]
sent [IPCP ConfReq id=0x20 <addr [MY PUBLIC IP]> <ms-dns1 212.159.6.10> <ms-dns3 212.159.6.9>]
rcvd [IPCP ConfReq id=0x70 <addr 195.166.130.255>]
ipcp: returning Configure-ACK
sent [IPCP ConfAck id=0x70 <addr 195.166.130.255>]
rcvd [IPCP ConfAck id=0x20 <addr [MY PUBLIC IP]> <ms-dns1 212.159.6.10> <ms-dns3 212.159.6.9>]
ipcp: up
Script /etc/ppp/ip-pre-up started (pid 13831)
Script /etc/ppp/ip-pre-up finished (pid 13831), status = 0x0
remote IP address 195.166.130.255
primary DNS address 212.159.6.10
secondary DNS address 212.159.6.9
Script /etc/ppp/ip-up started (pid 13877)
Script /etc/ppp/ip-up finished (pid 13877), status = 0x0
1 REPLY 1
adamwalker
Fixes: 204
Re: PPoE Based Disconnections?
Hi there, it sounds like there could be a fault. I've performed some diagnostic checks and we're not seeing any obvious causes but I still recommend following the checks here next: https://www.plus.net/help/broadband/connection-troubleshooting/
Once that's been done you can report a fault with us online at http://faults.plus.net
Do let us know how you get on.
 Adam Walker
