PPPoE router set up on ADSL2+
- PPPoE router set up on ADSL2+
01-12-2009 12:42 PM
I am currently running with a Linksys WAG354G. I am quite interested though to run this as a modem for a dedicated router perhaps a WRT54GL or Dlink 655.
Those two routers can only understand PPPoE....
If i set the Linksys WAG354G to connect via PPPoE instead of the recommended PPPoA will a PPPoE signal be passed on to the dedicated router or will it remain PPPoA?
Any help would be great.
Thanks!
Thanks!
Message 1 of 2
(1,072 Views)
1 REPLY 1
Re: PPPoE router set up on ADSL2+
01-12-2009 1:50 PM
From a quick Google dredge it looks like you can set the WG354G into bridge mode and whatever router you connect to it can use PPPoE.
Message 2 of 2
(305 Views)
