PPPoE changes?
- PPPoE changes?
Re: PPPoE changes?
19-12-2009 11:35 PM
I'm just wondering why do you want to use PPPoE? This adds overhead and possibly increase the ping latency.
Re: PPPoE changes?
21-12-2009 5:28 PM
So, I'm back on my Cisco ASA 5505, but my speed in the last few days has plummeted.. It's circa 700Kb/s...
If that is to do with moving to ADSL2, then yeah, move me back to ADSL1 please asap!!!
Cheers!
Re: PPPoE changes?
21-12-2009 6:06 PM
Re: PPPoE changes?
21-12-2009 6:10 PM
What is your IP Profile reported by the BT speedtest?
Re: PPPoE changes?
21-12-2009 7:16 PM
Quote from: psykix If that is to do with moving to ADSL2, then yeah, move me back to ADSL1 please asap!!!
The regrade order should complete on the 22nd of Dec 2009. this will get the line back on ADSL1.
Re: PPPoE changes?
21-12-2009 7:31 PM
Back on the Draytek 2800 for now - was unusable on the other one...
Syncing at 518000
Download speed on BT speed tester is 227Kbps.
IP Profile is 350Kbps
This is awful! I've never been getting less than 1Mbps, and typically 1.5Mbps...
Hope the regrade fixes it!
Re: PPPoE changes?
21-12-2009 9:39 PM
Try forcing your 2800 to use ADSL2 rather than ADSL2+. (Change the modulation on the Internet Access setup page.)
I'm on a long line and found the 2800 got *much* better speed using ADSL2 rather than ADSL2+!!!
It's worth a try at any rate until your line switches back to standard G.DMT!!
Re: PPPoE changes?
21-12-2009 9:52 PM
Fingers crossed that tomorrow I can go onto the Draytek Vigor 120 and my Cisco ASA 5505.
Re: PPPoE changes?
21-12-2009 10:13 PM
You'll probably have to wait 3 days for it to pick up again. You can check your IP profile here or by running a BT speedtest (the PlusNet one *should* match BT's but can be 12 hours behind).
I suspect that, unless you are moved back to 20CN, ADSL1 will simply be forced over 21CN (which you could also do by setting your router to ADSL1) and you'll have to wait for the profile to lift.
For an explanation of IP profiles see here. (Sorry if I'm telling you something you already know!!)
Re: PPPoE changes?
22-12-2009 11:29 AM
Download speedachieved during the test was - 189 Kbps
For your connection, the acceptable range of speedsis 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :1472 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1250 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.52:24.34:57.14 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Re: PPPoE changes?
22-12-2009 11:54 AM
If it doesn't that may well be the cause of your problem and you can either wait for it to fall in line or see if one of the comms team will nudge it for you.
Re: PPPoE changes?
22-12-2009 11:57 AM
No, PN profile is set to 350...
Doh... How long does it take to fall in line?
Re: PPPoE changes?
22-12-2009 12:08 PM
If you want it moved more quickly you could try PMing Mand or one of the other PN staff on here or calling support.
Re: PPPoE changes?
22-12-2009 1:08 PM
Quote from: psykix Aha!
It does now.
Re: PPPoE changes?
22-12-2009 1:20 PM
Will see how the speed goes over the next week.
Thanks for all the replies folks 🙂
