PPPoE authenticates, but no data
dooferlad
I have had a google around, but haven't found a solution to this one. I can authenticate using PPPoE, but I don't get any data over the connection. I have the same problem using a Mac, Draytek router connecting through a Netgear DGN1000 in modem mode and the DGN1000 just connecting using PPPoE. I am using an ADSL2+ connection. PPPoA works fine, but I want to use the Draytek router with the Netgear in modem mode (it gives far better wireless coverage).
Any thoughts?
James
1 REPLY
Fixes: 78
Re: PPPoE authenticates, but no data
AFAIK PPPoE can only be used on some but not all ADSL exchange equipment which is a likely reason for that.
 Adam Walker
