PPPoE Router disconnect/reconnect takes 5 - 6 mins?
- Re: PPPoE Router disconnect/reconnect takes 5 - 6 ...
20-03-2013 9:41 AM
Just after peace of mind on my FTTC connection.
I noticed with the supplied NetGear N150 and my upgraded NetGear N300 WNR2200 the action of selecting disconnect and then reconnect doesn't !, or at least go for a coffee and come back after 5 or 6 mins it does.
The same happens after a soft reboot.
Under a total house power failure like the meter swap out a few days ago, everything kicks and connects within a minute. Obviously the vDSL modem went off as well that time.
Tried a TP Link TL-WR1043ND and it does the same... Almost like there's a phantom PPP connection which has to time out first?
Sometimes unplugging the LAN cable to the vDSL seems to make it connect quicker, but maybe a coincidence as I'm getting worried fter 5 mins.
Do I have an underlying problem or is this delay the norm?
Pete
Pete
Message 1 of 3
(674 Views)
2 REPLIES 2
Re: PPPoE Router disconnect/reconnect takes 5 - 6 mins?
20-03-2013 9:50 AM
It's normal for me using the PN supplied TG582n
I suspect there's some sort of timeout at PN if the PPP session doesn't close gracefully.
Message 2 of 3
(323 Views)
20-03-2013 9:57 AM
Hi npr,
Thanks for letting me know it's not just me!
Strange as I was led to believe selecting disconnect was supposed to exit nicely but I'm having my doubts.
Doesn't fill you with confidence whilst playing with a million extra settings on my TP Link and every re-boot takes 5 or 6 mins to reconnect
Cheers
Cheers
Message 3 of 3
(323 Views)
