PPPoA or PPPoE - VC Based or LLC Based
Oxslow
After purchasing a Netgear  DGND3700 Router today I thought I would try auto detect setup.
I noticed that the setting it detected to use are PPPoE instead of PPPoA which I used to use and LLC Based instead of VC Based. So I am now using the wrong setting according to this.
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Should I manualy change them? Will I upset plusnet by using these settings?
Re: PPPoA or PPPoE - VC Based or LLC Based
PPPoE is known to work fine on ADSL2 services (I believe some forum members here actually get slightly better speeds using that over PPPoA) though I must admit I didn't know that LLC modulation worked - however you're showing online so it looks like all is good Smiley
We'll certainly not be upset if you keep using the same settings, if it's working then go for it.
Oxslow
After some testing I have found out that all 4 combonations work for me.
Thanks Matt for the quick reply.
Thanks for that, cheers for letting us know Smiley
Please pop back here if there's anything else we can do for you.
