PPP dropping since 09/05
- PPP dropping since 09/05
21-05-2013 11:33 AM
Hi All
For the past couple of weeks I've been receiving emails from my NAS about its inability to "register the IP address 0.0.0.0" to its DDNS service. Since last week I've also had another NAS in the house for a client and it's doing the same.
Checking the logs of these NASs (I don't always get the notification emails as they can't be sent unless a 'real' IP address has been assigned!) I see the incidents happening on:
09/05 03:02
15/05 14:01
17/05 07:21
20/05 14:36
21/05 02.22
The last one I've just now investigated by looking into the router's logs and the PPP connection was lost at 02:17:15 and was back up again at 02:17:44 so no major outage and to be honest I'd have never known if the NAS was not reporting.
Should I be concerned about this? Why has it just started happening though?
Cheers
Andy
09/05 03:02
15/05 14:01
17/05 07:21
20/05 14:36
21/05 02.22
Cheers
Andy
Message 1 of 6
(856 Views)
5 REPLIES 5
Re: PPP dropping since 09/05
21-05-2013 2:12 PM
I've posted a graph of your connection:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1369141722736.png"/>
You're not dropping PPP as often as you've reported, your line is very stable.
Have you changed anything on your network?
Message 2 of 6
(515 Views)
21-05-2013 2:39 PM
Hi Chris
Thanks for looking into this. I see from the graph that a couple of the dates/times agree exactly, others don't. Most intriguing!
No, nothing knowingly changed on the network. The second NAS was introduced last Thursday and has shown this 'error' twice (17/7 and 20/5) and my own NAS has been up for 12 days and shows four of these incidents. When it last restarted (9 May) it registered the IP address 87.115.208.196 but three hours later reported that it couldn't register the IP address 0.0.0.0!
It's the 0.0.0.0 that takes my interest - this can only come from the router, yes? If my DDNS service is down at the server end, which it is occasionally, then I'll get a notification but with a valid IP address given (the service has a 'heartbeat' function)
I don't have DDNS enabled on the router (TG852n) as the NAS takes care of that.
The router doesn't have any logs far enough back to look at any other incidents beyond the one last night, but last night's was caused by a PPP drop. So what else do you think could cause this? And as I say I never had this problem before 9 May.
Cheers
Andy
Cheers
Andy
Message 3 of 6
(515 Views)
21-05-2013 8:27 PM
The 21st @0217 looks just like the usual time when there's BT maintenance somewhere between your exchange and Plusnet.
Message 4 of 6
(515 Views)
21-05-2013 8:31 PM
Have you looked in the router log to see if you are losing sync briefly but not the PPP session?
Message 5 of 6
(515 Views)
21-05-2013 10:15 PM
@Anotherone. Good thinking that man. I wouldn't haven't made that connection.
@jelv. Not a long enough log to see beyond last night. Also I'm on FTTC so don't have sync stats.
Anyhow it's not a show stopper! More of a mystery. And as I say, without the NAS reporting I'd never have known.
Cheers
Andy
Cheers
Andy
Message 6 of 6
(515 Views)
