PPP dropped unable to authenticate - 18.00 on 17th Sept 2014
- PPP dropped unable to authenticate - 18.00 on 17th...
Re: PPP dropped unable to authenticate - 18.00 on 17th Sept 2014
17-09-2014 8:30 PM
I'm on pcl-ag06. Graph (http://www.thinkbroadband.com/ping/share-large/4aaacd430d2a57e2be2ea4fd7f01c061.png) is showing some packet loss but awesome latency. Traceroute to www.google.com is as follows:
traceroute to www.google.com (74.125.230.242), 30 hops max, 38 byte packets
1 lo0-central10.pcl-ag06.plus.net (195.166.128.187) 13.094 ms 16.285 ms 15.852 ms
2 link-b-central10.pcl-gw02.plus.net (212.159.2.182) 12.954 ms 12.654 ms 12.694 ms
3 xe-10-3-0.pcl-cr02.plus.net (212.159.0.214) 14.964 ms 12.867 ms 13.390 ms
4 ae1.ptw-cr02.plus.net (195.166.129.2) 13.378 ms 12.637 ms 12.749 ms
5 72.14.223.32 (72.14.223.32) 12.902 ms ae2.ptw-cr01.plus.net (195.166.129.4) 14.704 ms 13.100 ms
6 72.14.222.97 (72.14.222.97) 13.155 ms 209.85.252.186 (209.85.252.186) 12.886 ms 12.865 ms
7 209.85.250.169 (209.85.250.169) 12.962 ms 209.85.246.244 (209.85.246.244) 24.745 ms 13.568 ms
8 par08s10-in-f18.1e100.net (74.125.230.242) 12.950 ms 209.85.250.169 (209.85.250.169) 13.121 ms 13.111 ms
17-09-2014 8:30 PM
Ex-Broadband Service Manager
17-09-2014 8:32 PM
17-09-2014 8:35 PM
Any eta yet?
17-09-2014 8:36 PM
Quote from: Kelly is your latency ok generally? Run a ping -t www.google.com and leave it for a bit and see how much time varies.
What does the -t flag do? Mac OS X doesn't like the command with the -t. Generally latency seems fine to me; no gamers in the house.
--- www.google.com ping statistics ---
84 packets transmitted, 84 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 23.140/26.051/30.360/1.067 ms
I've got another ping running and will leave that for a bit longer.
17-09-2014 8:39 PM
Quote from: chenks76
Quote from: hocumgday It's not the cost of downtime it's the cost of many elements lost through downtime. I have had disconnects after disconnects with plusnet and I have been very, very patient, I have had BT engineers out on several occasions and every time they have diagnosed the fault back to plusnet!
that's not relevant to this issue though
How is it not relevant? Maybe if you read the last few posts you made you will actually see it is relevant to what you posted.
Stop pretending to be a pacifier for PN when you clearly, as stated, have nothing to do with them. If you have something to say, say it, instead of replying to people's posts that might be a tad disgruntled of this situation.
Cheers ;0)
17-09-2014 8:39 PM
17-09-2014 8:40 PM
Cannot recall what gateway I was on and have yet to check the current gateway.
Seems to have been very widespread???
Oh and though the IP is 3.48 my speed is 2.90
17-09-2014 8:40 PM
Quote from: Kelly A tiny nice thing from this: I'm at home and was connected to ptn-ag04.plus.net so didn't disconnect. My download speeds have dropped down from 50Mbps to about 14Mbps because of the over subscription of this end point, but there are two people in my front room gaming and my latency is completely unaffected.
I was lucky to escape the disconnect too. I was even luckier for it not to have affected my download speeds (pcl-ag01):
What is interesting (and probably for another thread) is the packet loss I saw on IPv6:
That wasn't seen over IPv4:
Quote from: destin8 What does the -t flag do?
Runs the ping indefinitely until you escape it.
17-09-2014 8:42 PM
Quote from: Kelly ah, -t just leaves it going till you kill it.
Thanks for explaining. Macs do it the opposite way to Windows then -- it keeps going by default here.
17-09-2014 8:46 PM
17-09-2014 8:50 PM
17-09-2014 8:50 PM
882 packets transmitted, 881 packets received, 0.1% packet loss
round-trip min/avg/max/stddev = 22.858/26.534/85.518/5.003 ms
17-09-2014 8:50 PM
Pings look fine well in the range they normally are
Ping statistics for 212.58.244.18:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 13ms, Maximum = 17ms, Average = 14ms
17-09-2014 8:51 PM
