PPOA
HaresEar
PPOA
According to my hubs log file my PPOA connection has been very unstable. Internet pin latency is high. Spped is OK but it is taking for ever to connect to all sites. Any idea what this is.  Are plusnet stiil having problems?
My upload speed is non existent too
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
Download  Speed
7.97 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speedachieved during the test was - 7.97 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.49 Mbps
Upload Speed
0.1 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.1Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Fixes: 229
Re: PPOA
Most of the drops are happening in the early hours of the morning.
With regards to the upload speed are you connecting over a wired or wireless connection?
 Matthew Wheeler
HaresEar
Re: PPOA
I have tried both wired and wireless and I get the same result.  Any ideas why I  am I getting these drops anyway?  This seems to have started after the Major outage PN had recently.
Fixes: 26
Re: PPOA
When you plugged in a wire, did you disable the wifi?  Unless you did, you can have no assurance that when the wire was plugged it, it was being used in prefernce to the still working wifi.
Please post here all of the information requested in the speed issues thread.
