PN update wordpress.
WendyDavies
Hi Plusnet, Just wanted to let you know that your wordpress blog needs updating, It only takes a couple of clicks and should include some improvements.
WordPress 3.5.1 is the new update the site is currently on 3.3.1 (its quite behind.)
URL: http://community.plus.net/
Just wanted to give you a heads up on this.
Many Thanks
Fixes: 70
Re: PN update wordpress.
Thanks Wendy, we're aware of this however updating isn't quite as simple as the usual click from the admin interface. We have two Wordpress installs on the Community Site and the SMF install that powers these forums. All three 'talk' to each other and there are also ties back to our CRM systems and our main website when registering etc.
The Wordpress installs also run custom-built plugins that may not be compatible with newer versions and require re-factoring.
It is on our list of things to do.
Plusnet Products Team
WendyDavies
Ah Ok, As a MU application i guess its checking to see if everything works before deployment. Anyway Glad to hear its on the list of things to do Smiley
Fixes: 126
it's a very long list though Roll eyes
Will Moderate For Thanks
