PN router keeps dropping
- PN router keeps dropping
14-12-2016 9:23 AM
We have had Plusnet since June 2016 with no issues.
Recently, the router keeps losing its internet connection every 15 minutes.
The only change I made, within the PN hub settings, was to restrict some of the mobiles to 2pm until 10pm.
I have since cleared this but the problem is still there.
Jamie
Re: PN router keeps dropping
14-12-2016 9:54 AM
Your line is disconnecting very frequently:
Testing your line isn't showing any obvious problems:
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 40.0 Mbps |
Upstream Speed |
2.0 Mbps |
Is there any noise on the phone line when you plug a handset in and dial 17070 running the quiet line test.
14-12-2016 10:41 AM
The line is quiet
16-12-2016 9:55 AM
We have not had this problem resolved. The PN router keeps losing the internet. Does anyone have any suggestions.
Jamie
16-12-2016 9:58 AM
Have you tried a factory reset of the router? Plusnet will probably ask you to try it at some point so you might as well get ahead of the game.
Guide at https://www.plus.net/help/broadband/router-user-guides/
16-12-2016 12:18 PM
My problem is a mirror of Jamiemackay 's and has been going on for more than a fortnight. I have phoned the PN help line many times but there has always been a waiting time of 45 minutes. NOT GOOD ENOUGH PN!
I seem to have 2 kinds of disconnection (a) total (occasional) and (b) short-lived (frequent).. I am on the Madderty exchange (ESMAD), PN username: arcadian. I have done the following:
1.Connected directly into the back of the BT Master Socket - NTE5
2. Done a quiet line test (it is quiet)
3. Reset my router (Technicolor TG582n )
I have left my PC connected with an ethernet cable to the back of the master socket so that you can do a line test.
Your help would be much appreciated
P.S. It used to be much easier when one could "raise a ticket" online and then wait for a phone call and/or an email.
17-12-2016 5:30 PM
Apologies for the continued problems.
If you haven't already I'd recommend getting this raised to us at http://faults.plus.net as it's likely we'll need to arrange an engineer.
20-12-2016 5:10 PM
could be the same 60Khz hum that I had you cannot hear it with you ears but a radio should pick it up if you place it near your phone line
